Transmission cooler
Old Mar 31, 2006 | 01:32 PM
dr-rjp's Avatar
Transmission cooler
With warm weather coming, i'm thinking of putting in a transmission cooler.
Any recommendations as to brands?
Any other gains besides increeased transmission life?
Old Mar 31, 2006 | 01:37 PM
MaxGordon7's Avatar
i just put mine in, get hayden model. I when to autozone and it was a piece. I when to napa, paid a little more but well worth it. Might try ordering it on ebay, save a bit. It saves the life of your tranny, what more would you want?
Old Mar 31, 2006 | 02:21 PM
NewLoveI30's Avatar
You can safely put more power through it
Old Apr 1, 2006 | 08:58 AM
Tim96I30t's Avatar
I am doing the same to my I30t, summit has them starting at about $40 and has many sizes and coooling capacities. I want to add a trans temp gauge when I do this as well so I can see the temp difference before and after install of cooler.
Old Apr 1, 2006 | 04:33 PM
attomica
For those of you who have installed one, any chance of a write-up?
Old Apr 3, 2006 | 05:16 PM
i30ds's Avatar
Armed and Dangerous
Why not just pick up a summit catalog and make your own?...
Old Apr 4, 2006 | 09:04 AM
Tim96I30t's Avatar
thats what I said.....$40 bucks up to 18000 GVW summit
Old Apr 4, 2006 | 03:32 PM
i30ds's Avatar
Armed and Dangerous
Missed that post. If I was auto that is what I would do...
Old Apr 5, 2006 | 09:07 AM
Tim96I30t's Avatar
Why 5 speeds can't benefit from this or you can't hook it up on a 5 speed? I read fast and miss sh@t all the time.....thank god for edit
Old Apr 5, 2006 | 12:05 PM
i30ds's Avatar
Armed and Dangerous
It has been discussed from time to time. I don't think anyone ever got around to doing it. I just don't think the oil gets hot enough and even if it did, there would be no way to get the oil to flow into the cooler as there is no pressure like in an auto tranny. In a 5 speed, the oil just sits there and the gears splash around in it.
Old Apr 7, 2006 | 11:37 AM
Sloppy Snood's Avatar
Tranny Cooler Installation on '99 SE Automatic
Here's one from Greg's Garage on a 1999 Maxima SE with an Automatic tranny. This is a pretty informative install for a Hayden tranny cooler.
http://www.greghome.com/Greg's%20Gar...n%20Cooler.htm
Let us know how your install goes. - Sloppy Snood
Old Apr 7, 2006 | 05:15 PM
attomica
Perfect! Thanks for that.
Old Mar 27, 2014 | 11:11 AM
chrisconley1's Avatar
tranny cooler
So you run the fluid through the cooler AND still run it through the radiator as well? What's the point of running it through both? Wouldn't that be a lot more work for the pump to handle?
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Pied
Sep 26, 2015 03:29 PM
