96 I30, no speedo no odometer
Old Jun 20, 2006 | 09:46 AM
internetautomar's Avatar
mod or sell?
I picked up this I30 but the odometer and speedometer don't work.
Trans shifts fine as near as I can tell. No codes came up on my scanner.
well, I did come up with a bad o2 sensor code
Old Jun 20, 2006 | 11:45 AM
hasei's Avatar
日産
If you don't have a VSS code, chances are, you may have to replace your speedometer. It's somewhat common especially among 4th Gen. Maximas. Sometimes re-tighten all screws that hold speedometer to the cluster will fix this issue, even if the screws don't look loosen, you can try it before replacing the speedometer. Replacing a VSS to see what happens is another option, because obviously it's cheaper than replacing a speedometer. In my experience this issue with AT transmission sometimes coninsides with flashing O/D lights indicating a TCM error.
Old Jun 20, 2006 | 01:53 PM
mod or sell?
I guess I'll tear into the cluster tomorrow then.
no O/D light on, just flashing airbag.
maybe I'll scan that code tomorrow
Old Jun 20, 2006 | 01:59 PM
i30ds's Avatar
Armed and Dangerous
Need new speedometer. Tighten the screws on the back of the cluster can put a temporary fix on problem.
litch
123
Jan 4, 2024 07:01 PM
mvm062
Nov 30, 2020 09:00 AM
mkaresh
Mar 12, 2018 06:48 PM
uttadms31
Sep 30, 2015 05:24 AM
