Driveshaft on a I30 and I30T
Old Jul 9, 2006 | 08:49 AM
cr00klyn718's Avatar
Wanted to make sure the 97' I30T is the one with the diff, and that the I30 is the model without the diff.
B/c im not sure which axle i need for my I30 base model.
Can ne body confirm this real quick.
Old Jul 9, 2006 | 11:20 AM
Also on the title of the post i mean axles not "driveshaft" lol
Old Jul 9, 2006 | 05:07 PM
internetautomar's Avatar
mod or sell?
the "T" models came with the limited slip differentail AKA High Speed Differential
Plain models it was optional.
BTW it is also noted on the plate on the firewall as well
Old Jul 9, 2006 | 05:56 PM
Plain models did not.
O yeah I checked the model number and it does have an LSD.. , but now the drive-axle seal is leaking.
Old Jul 10, 2006 | 10:01 AM
i30ds's Avatar
Armed and Dangerous
Both have a diff. The issue is wheater your car has a limited slip diff which uses a different differential side oil seal (larger). All ts have the lsd. Non ts might or might not have it. Check your firewall plate to find out.
Old Jul 10, 2006 | 05:10 PM
trbosqrl's Avatar
I Have A Base Model I30 With Vlsd
Old Jul 10, 2006 | 10:49 PM
talisman311's Avatar
any of you guys with LSDs have final drive noise? Basically a humming noise relative to the speed?
Old Jul 11, 2006 | 09:37 AM
mod or sell?
no one should out of the factory LSD.
My VE doesn't and it has the factory VLSD
Old Jul 11, 2006 | 09:57 AM
Well, I didn't used to.. 'til ~120k miles. Took it to infiniti and explained my problem, he said that was the cause. I thought it was my wheel bearing but I still have it after the replacement. New tranny replacement is somewhere in the range of 2200 dollars so I'm trying to see if anybody has the same issue.... and so far, I think i'm the only freakin' one.
Old Jul 11, 2006 | 11:28 AM
i30ds's Avatar
Armed and Dangerous
That is pretty rare!!
Old Jul 11, 2006 | 11:29 AM
i30ds's Avatar
Armed and Dangerous
No noise here.
Old Jul 12, 2006 | 12:17 PM
Double E's Avatar
Almost 140K & no tranny noise.
Old Jul 12, 2006 | 05:31 PM
Ugh, blah.. I guess I'm screwed - anybody know where to find a used VLSD auto?
Old Jul 13, 2006 | 11:05 AM
i30ds's Avatar
Armed and Dangerous
car-part.com
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
uttadms31
Sep 30, 2015 05:24 AM
jerrod99_se-l
Sep 25, 2015 03:02 AM
