I30 Check Engine light P1445
evap stands for evaporative emmisions, gas fumes can't be let into the atmosphere, they have to be stored and purged into the intake so they can be burned off. Common spot for problems on the 4th gen is under the car, in front of the gas tank, behind the rear door on the drivers side you'll see a little black plastic cover, look above it and make sure there isn't a problem with the hoses first, then get a manual and go from there.
i check the hoses.. it looks fine.. i don't see any leakage..
Where is purge volume control valve locate it... ?
i can't find chiltons or Haynes repair manual? should i buy maxima repair manual...?
please provide me with more information...
thanks
thanks
Malfunction is detected when:
A) Improper voltage is detected from the valve by the ECM. Check items: harness, connectors.
B) Canister purge flow is detected during specified driving conditions even when EVAP canister purge volume control valve is completely shut off. Check items: EVAP control system pressure sensor, EVAP canister purge volume control valve (valve is stuck open), EVAP canister purge control valve, hoses (connected incorrectly).
The EVAP canister purge volume control valve is located behind the throttle cables above the intake manifold.
Get the Maxima Chiltons/ Haynes manual. You're gonna need it.
EVAP canister purge volume valve parts...
okay... i need to purchase this EVAP canister purge volume valve..
someone please provide me with part #'s and place where i can get this low pirce...
Than you all.. again..
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
