View Poll Results: What do you think is the cause?
MAF sensor
50.00%
O2 sensor
0%
Coils
0%
Fuel filter
0%
Something else
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
2000 I30t Died Again During Cold Start
Old Jan 3, 2007 | 03:42 AM
MaximaExposure's Avatar
It's been a month since it last died on me, so I thought the problem went away, but nope, it's back... After searching around, it sounds very much like a MAF sensor going bad. This only happens during cold starts and I put it into gear right after start up, it would stutter with very low RPM for a few seconds, then it dies, but if I give it gas, it would be ok. It seems others with bad MAFs would experience loss of power at 3500RPM, I've never drove it that hard before, so I don't know if mine would do that.
Is there a way to diagnose the MAF sensor? What voltage should it read during a cold start? In Park? In Reverse? In Drive? I want to make sure it is the MAF sensor before I buy it from Dave B.
Old Jan 3, 2007 | 03:56 AM
brio_max's Avatar
Learning English...
"Use the repair in this bulletin if a 2000 I30 exhibits the following symptoms: After starting the vehicle in ambient temperatures below 40° F or +5° C, the engine idle drops excessively or stops when shifting into "D" or "R" range. This incident is not A/T-related and typically occurs within the first minute after the engine is started cold. Once the engine warms, the incident no longer occurs. There is an updated ECM program available to address this incident if it should occur. Use the Service Procedure outlined in this bulletin to correct this condition. "
The info is from HERE
I had the same problem with my first Max(i30) A33 A/T and after getting a new MAF the problem eas still there... You can't imagine how happy i was when i sold my car... ;]
Old Jan 3, 2007 | 01:59 PM
Wow thanks, that's the exact symptoms I am experiencing, no more, no less. Did you fix it before you sold the I? It sounds like all I need is an updated ECM program. I wonder how much the stealers would charge me for it...
Old Jan 3, 2007 | 03:02 PM
brio_max's Avatar
Learning English...
No, i didn't fix, probably because the dealer did not reflash the ECU... Also my tranny was slipping from 2nd to 3rd gear and after other small problems..., i decided to sell the car.
I think the reprogram would help you or a new MAF + ECU reflash(+- 100$).
sctludwig
Sep 1, 2022 01:32 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
GregL65
Sep 7, 2015 10:33 PM
trungg86
Sep 4, 2015 04:58 AM
