I30 ECM code check and reset
Old Aug 19, 2007 | 01:24 PM
Gary95's Avatar
I searched around but haven't been able to find what I'm looking for. My parents have an Infiniti I30 (I have a '95 Maxima SE) where the check engine light periodically comes on. My hunch is that it is the O2 sensor, as this is what would periodically trip my ECM on the Maxima and cause the engine light to come on. Given that my folks are elderly and don't live next door, they take it to the dealer who charges them $54 to reset it, every few months or so. Ridiculous.
I downloaded the I30 service guide from PhatG20 and I *think* I see that it is located where the Maxima one is (behind the center console). So, I pull off the black plastic protector and see two holes covered by a thick piece of tape. I pull the tape back and I do not see any screws, as I'd see on the Maxima.
Is this ECM only resettable by using a special tool, or can you use a screw driver? I saw some people say Autozone will check it for you and tell you the code information for free--do they reset it as well? Thanks!
~Gary
Old Aug 19, 2007 | 04:51 PM
KRRZ350's Avatar
Around here the autozone's will only check it but not reset it for you anymore. You failed to mention what year it this I30 is? If it is 96-99 it should have the same screw and procedure as your maxima, if it is a 00-01 than you must use a consult or obdII scanner.
Old Aug 20, 2007 | 06:41 AM
Gary95's Avatar
Ah, sorry -- my bad. It's a 2000 model. Bummer, I thought that Nissan/Infiniti would make a dual system where the old "flashing check light" or the OBD scanner could be used. I guess it's a trip to Autozone then. Thanks!
Old Aug 20, 2007 | 11:30 PM
i30ds's Avatar
Armed and Dangerous
...If it is 96-99 it should have the same screw and procedure as your maxima....
The screw driver method only works on 96-98.
Old Aug 21, 2007 | 06:21 AM
Double E's Avatar
Gary,
Can you tell me exactly what location the "behind the center console" is referring to? For example, I'm pretty sure you're not talking about the arm rest console or the overhead console.
I've looked all over myself on my 97 and I'm pretty sure I'm just not looking in the right place.
Old Aug 21, 2007 | 02:11 PM
KRRZ350's Avatar
It's right next to the gas pedal, just pop off the black plastic cover and you'll see it.
Old Aug 22, 2007 | 05:14 AM
Double E's Avatar
Sweet. Thanks as always...
sctludwig
Sep 1, 2022 01:32 PM
RinconI30
Nov 10, 2015 10:55 PM
bryants95max
Oct 2, 2015 12:52 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
