Speed Sensor Wire and Park/Neutral Position Wire Location?
Old Aug 10, 2008 | 06:52 AM
ZGadson's Avatar
Anyone know where I might find these wires?
I need to find where the Unified Meter Control Unit and the Park/Neutral Position Switch are located. Can anyone point me in the right direction?
Old Aug 11, 2008 | 04:19 AM
brio_max's Avatar
Learning English...
Did you find them?
Old Aug 11, 2008 | 06:00 AM
ZGadson's Avatar
Nope.
Old Aug 11, 2008 | 06:29 AM
MaXiM@KiD's Avatar
MaXXiN
what yr is your car and where are you located?
Old Aug 11, 2008 | 07:51 AM
brio_max's Avatar
Learning English...
Your car is I35, right?
OK, i do not know about the wires, but the meter control unit should be located in your cluster
and the park position switch is under the shifter.
I'm not sure, if this helps
Old Aug 11, 2008 | 10:34 AM
ZGadson's Avatar
Sweet! Thanks, man! I'll have to try that when I get home!
(Its an i35, and I live in South Bend, IN.)
Also, I was wondering why it needed the reverse signal from the gear position switch and not the Drive signal. That doesnt make sense.
Old Aug 11, 2008 | 04:56 PM
SVI30's Avatar
In the very back of the Electrical section, there is a location map of where all the connectors are located. It is a rough location so it is still tough to find individual connectors.
Old Aug 12, 2008 | 03:06 PM
ZGadson's Avatar
Got instructions for how to remove the center console? I can't remove the gear shifter with the console still in place.
Or, is there another place where I can tap into the reverse signal? (I don't really want to run a wire all the way to the reverse lights, but I will if I have to.)
Old Aug 12, 2008 | 04:45 PM
KRRZ350's Avatar
My guess is that it is so that it knows when the car is in reverse so it won't flip the direction around. The p/n switch in the diagram you posted is NOT located on the shifter assembly, it is in the engine bay, on the side of the trannsmission, it's a big black plastic thing right on the front of the trans that is shaped kinda like california. This 12v signal does pass into the center console area though because in addition to the back-up lamps it also goes to pin 35 of the tcu . Access to the tcu can be tricky, but the up-side is that this wire appears to maintain g/w throughout
It's already kinda been stated, but the "unified control meter" is the fsm's name for the gauge cluster.
Old Aug 12, 2008 | 08:17 PM
ZGadson's Avatar
ITS ALIVE!!!! MUAHAHAHAHAHA.
Yes. It works now. I'll post a write-up & picts as soon as I have time.
Old Aug 15, 2011 | 12:24 PM
walaa's Avatar
thanks for all
Old Aug 15, 2011 | 12:36 PM
pahanorlando's Avatar
Originally Posted by walaa
thanks for all
NO WAY, are you SERIOUS?
mrc00l88
Jan 25, 2024 01:14 PM
95Maxi
35
Sep 2, 2015 10:37 AM
