98 I30 running rough, need help
Old Aug 10, 2008 | 08:09 PM
gakary54's Avatar
I drove the car last night and it was fine. Go out today, it starts then dies right away. On the 3rd try, I give it gas and it starts, but is idling very rough. At low speeds I can hear a chuga-chuga sound. At highway speed it seems to get a bit smoother. The check engine light is now on, but every so often, it starts flashing. I have always put premium gas in it. Any help would be greatly appreicated. Thanks.
Old Aug 11, 2008 | 03:15 PM
gakary54's Avatar
Could the exhaust cause the problems I am having?
Old Aug 11, 2008 | 04:16 PM
rxm6's Avatar
From the sound of it, sounds like a vacuum leak to me. Check your hoses against your vacuum diagram and see if you have a leak somewhere.
Old Aug 11, 2008 | 04:59 PM
SVI30's Avatar
Read the engine error codes and search in the 4th Gen Maxima forum as see what other owners are saying.
Old Aug 11, 2008 | 06:00 PM
gakary54's Avatar
Thanks for the help. The check engine light does'nt seem to have a pattern. It will start flashing out of nowhere and then stop just as suddenly. I will check the hoses and hope thats the problem. Again, thank you both.
Old Aug 11, 2008 | 08:50 PM
tHe iLleSt RiCe's Avatar
get the ecu checked for codes, theres obviously a code there that can help diagnose the problem.
Old Aug 12, 2008 | 09:06 PM
gakary54's Avatar
It was a bad coil pack. I forgot which number it was, if you are facing the engine it was the one on the left closer to the front. Thanks for the help.
Old Aug 13, 2008 | 04:26 PM
rxm6's Avatar
^awesome
Old Sep 1, 2008 | 12:27 PM
JSR15's Avatar
Hey, I'm a new member and can't post threads so sorry for stealing this thread. I have a 98 I30 and I need to replace my CV Joints and I was wondering if anyone here knows what a good price for a job like that is?
Old Sep 1, 2008 | 10:05 PM
rxm6's Avatar
Next time post in the "I'm new here but have a q" thread. But, you are looking at about 1 hour of labor for each joint plus the cost of the joint which is about $130-$150. So if you need both done about $450-$500.
Old Sep 4, 2008 | 05:43 PM
JSR15's Avatar
Thanks for the help, I'll definitely be getting that done soon.
Mar 12, 2020 12:06 AM
RinconI30
Jun 11, 2016 08:25 PM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
