Changing the high mount brake light bulbs....
Old Jun 19, 2009 | 10:43 AM
VeeTec's Avatar
I searched, what's the procedure? This is on an I35's rear deck brake light. I have checked from under the trunk, and above the deck. The assembly will move a little, but I don't want to break it trying.
Old Jun 25, 2009 | 10:21 PM
VeeTec's Avatar
I found the directions in the owners manual, of all places.
All you have to do is push the back of the light towards the window, two hooks will clear the deck, then tilt the assembly up, and pull it back gently, towards you.
Make sure to use the Nissan bulbs too, as the 168 will not light up as well, or as quickly, as the Toshiba T20 5 watt bulbs.
Old Nov 4, 2010 | 05:01 PM
Hurricane05's Avatar
You found that info in the owners manual? I have a 2011 and would like to remove mine.
Old May 17, 2011 | 02:11 PM
jmaster1's Avatar
need to reeplace hight mounted brake light on 2000- 20004 nissan maxima dont have a clue?
jmaster1's Avatar
help...
Old Jun 21, 2011 | 07:18 PM
tsi1991awd's Avatar
There are small clips that push in then the light pops out. You dont push toward the window because the light is already against the window.
Old Jan 31, 2012 | 10:04 PM
myclean07's Avatar
i need to replace the light thats in the spoiler! anyone know where i can get a replacement? ive looked all over the web and all i can find are the spoiler / light assembly.
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
RealityCheck
Aug 5, 2015 06:18 AM
