Lets see those i30/i35's!
Old May 15, 2014 | 06:13 PM
  #401
Infi30t's Avatar
Originally Posted by 95naSTA
Picked up a new OEM front bumper and had it painted
Still have to pick up a new chrome strip
You're car is BEAUTIFUL. That has to be one of my favorite colors.
Old May 15, 2014 | 10:35 PM
  #402
NismoCefiro's Avatar
Originally Posted by SpeedCrazie
looks good, how was the 5 speed swap? Interior pics?
Was planned. I did it 6 years ago. When I did it I planned it out 1 year advance, spent 6 months getting the parts. Got new, 20th AE tranny from dealership, 1800 bux. New bolts, centerforce dual friction clutch, chromoly flywheel, b&m shifter, manual motor mounts, ebrake and cable for maxima and 20AE pedals. Got used shift linkage, clutch pedal, brake pedal and manual ecu. I had the ebrake mount custom made. I designed a custom block to match the height of the maxima ebrake and had it cnc made then drilled 4 bolts to the chassis to mount. The blocks were tapped for standard nissan metric bolts. Using amsoil gl-4. Have put 100,000+ miles on and still on original clutch. One thing though, ur immobilizer is keyed in the ecm. I ran on auto ecm to dealer then when programmed, its $125 flash or key, so I made them do latest flash for the ecm and 17 BTDC advance timing from consult with the key program. She's a champ. I have 215,000 miles and idles like a brand new car and I still rape anyone who thinks its just an infiniti i30 ...
Old May 15, 2014 | 10:44 PM
  #403
SpeedCrazie's Avatar
Nice Work! What did you do for the shifter trim? And you cut a hole in original console for the ebrake?
Old May 16, 2014 | 07:18 AM
  #404
95naSTA's Avatar
Thanks!
Old May 16, 2014 | 09:06 AM
  #405
Yea, dremel the center console for the ebrake. The shifter is the same automatic opening. With the B&M shifter, it does not touch the trim. I just bought a shift boot and glued it to the bottom of the trim. I also did not install a clutch switch. I instead wired the neutral/reverse so that if the car is in a position outside of neutral, the car will not turn over.
Old May 18, 2014 | 02:17 AM
  #406
deloa84's Avatar
Well this is my brothers i30 that he just recently picked up.... Should be a fun car... I'm actually a bit envious of him since it is rather clean...
testing some g35 18s
Old May 19, 2014 | 09:59 AM
  #407
dwapenyi's Avatar
Sign into microsoft's Live just to see the images?
Old May 19, 2014 | 12:04 PM
  #408
deloa84's Avatar
Sorry fixed... Switched to photobucket...
Old May 20, 2014 | 12:05 AM
  #409
dwapenyi's Avatar
Nice
Tell your brother to polish those glass headlights......that's a 96 I30 I presume?
Old May 20, 2014 | 12:28 AM
  #410
deloa84's Avatar
Nice
You sure know your I30's. Yes its a 96. The headlights are plastic thought they are not glass. He will clean and buff it out soon...
Right now I told him to focus on doing some maintenance. We just finished installing new valve cover gaskets, cleaned egr, TB, etc and filling the torque mounts with 3M window weld. BIG difference in acceleration and the engine isn't flopping around anymore.
Next he wants some lowering springs and new shocks and that is about all it needs. With 200k the car still runs like a champ and the previous owner had really good maintenance records and used oem parts (for the most part).
Old May 20, 2014 | 02:05 AM
  #411
mayur914's Avatar
Yes polish those headlights and possibly retrofit with 98-99 headlights or cefiro headlights. Only maxima 95-96 had the glass headlights not the I30.
Old May 21, 2014 | 04:54 AM
  #412
dwapenyi's Avatar
Interesting...OK.
How did u black out your grill but leave the infiniti logo all chrome and shiny? That's a cool look.
Old May 22, 2014 | 03:58 AM
  #413
mayur914's Avatar
Interesting...OK.
When you take out the grille. you can take out the emblem from the grille and spray the grille only, simple. Retrofitting is a good way to go for safety on the road for lights.
Old May 22, 2014 | 06:40 AM
  #414
dwapenyi's Avatar
....you can take out the emblem from the grille....
I tried that and was worried that once I took the emblem off, it'll never go back on and stick for good.
Old May 22, 2014 | 11:33 PM
  #415
mayur914's Avatar
That happened to me but you can probably get some removable tape or something that you can use. the first time i painted the grille, I used duplicolor and the emblem didn't stay, but after plasti dip it stuck fine.
Old May 23, 2014 | 05:33 PM
  #416
AliasJR's Avatar
Hey what are the measurements of your wheels, they look great on the car and where did you get the entire headlight assembly?
Old May 26, 2014 | 08:29 PM
  #417
95naSTA's Avatar
Wheel specs are 18x8 et 20 front, 18x9 et 22 rear. The rear fenders are rolled and the fronts are rolled and pulled. Also running over a degree of negative camber up front.
Edit -
The headlights were bought off of a member here but they're whatever is on ebay.
Old May 27, 2014 | 06:39 PM
  #418
Pronk's Avatar
Here's my new car, 2000 I30 with 153k
Old May 27, 2014 | 09:02 PM
  #419
MaxMike93's Avatar
Another Aspen White Pearl owner!
Old May 28, 2014 | 05:07 PM
  #420
Pronk's Avatar
Your car is so clean! Its my inspiration, ha
Quick question- is there anywhere else to get clear side marker lights for our cars other than Klearz? I've checked ebay,
Klearz price seems kinda outrageous to me, ha
Old May 28, 2014 | 07:49 PM
  #421
MaxMike93's Avatar
Your car is so clean! Its my inspiration, ha Quick question- is there anywhere else to get clear side marker lights for our cars other than Klearz? I've checked ebay, Klearz price seems kinda outrageous to me, ha
Thanks!
Klearz is the only one with a current stock. The company that used to make them, Paradox, went out of business so for their side markers it's either waiting on eBay for a random set or seeing if a set comes up in the Classifieds. The Klearz are a bit pricey, especially compared to the amount you can find for a 5th gen Maxima, but they were the only ones around and I prefer how they are the textured lens rather than the clear one on the Paradox sets. And it is an Infiniti after all so sometimes you have to pay to play haha
Old Jun 1, 2014 | 01:17 PM
  #422
DinoSR20's Avatar
Old Jun 1, 2014 | 07:52 PM
  #423
MaxMike93's Avatar
Originally Posted by DinoSR20
Ouch
What happened? Any frame damage? I'd hate to see an I30t in that color get totaled
Old Jun 2, 2014 | 12:48 PM
  #424
Joeker82's Avatar
Ouch
Ouch, sorry man! That is definitely a total loss..
Old Jun 2, 2014 | 09:22 PM
  #425
LaadiDaadi's Avatar
Got my '96 i30 back in December with 148 on it, now she has around 153. Recently just changed the rear valve cover gasket, lower control arms, and changed from hids to oem halogens (bad decision). Only real "mods" I've done was put in an JVC bluetooth deck and a kicker l5. I'm planning on buying some cefiro one-piece headlights and lowering it on springs and maybe KYB struts. Might also paint it.
The day I picked her up
Kind of messed up my door recently
As she sits now after a wash
Old Jun 11, 2014 | 09:10 AM
  #426
03_I35's Avatar
Old Jun 30, 2014 | 06:56 PM
  #427
95naSTA's Avatar
Some recent shots
Old Jul 1, 2014 | 11:51 AM
  #428
D I R T Y I 3 0's Avatar
Some recent shots
Still clean as ever I see
Old Jul 20, 2014 | 01:39 AM
  #429
thenewguyy's Avatar
Some recent shots
whats your suspension setup?
Old Jul 20, 2014 | 03:34 PM
  #430
95naSTA's Avatar
@Dirtyi30 - Thanks man.
@the newguyy - BCs up front and JICs in the rear.
Old Sep 2, 2014 | 06:31 PM
  #431
Bklyndeem's Avatar
My Baby
Not As Nice As You Guys But....its a Work in Progress https://maxima.org/forums/picture.ph...ictureid=39062
Old Sep 8, 2014 | 10:05 AM
  #432
rbaksi's Avatar
Love the black wheels man
Old Sep 12, 2014 | 05:18 PM
  #433
thenewguyy's Avatar
not bad, was the rear painted cause I see a different shade starting from the end of the rear passenger door. Also whats your suspension setup? What tire sizes did you go with? Any rubbing issues?
Old Nov 13, 2014 | 08:45 PM
  #434
Bklyndeem's Avatar
thanks a lot bro! I'm trying.
Old Nov 13, 2014 | 08:48 PM
  #435
Bklyndeem's Avatar
yea it is a different shade i got it painted over by a shi**y shop, but i plan on getting the whole car painted over in 2015(same color) and about my wheels the rear does rub a lil I'm running 245/45/18 w/o spacers. Im changing to 235/40/18 all around next year.
Old Nov 24, 2014 | 01:25 AM
  #436
mayur914's Avatar
Here is an update pic of the ride as of 11/08/14:
Has the 350z V1 track wheels
Fog projectors and ditched the old 3M taped deflectors for some weathertech deflectors
Old Nov 28, 2014 | 08:47 PM
  #437
thenewguyy's Avatar
cool man, keep me posted as I might be doing G35 wheels on my ride with most likely a drop so would be nice to know which setup of tires wont rub
Old Mar 31, 2015 | 08:08 AM
  #438
ChemDog's Avatar
99 i30
Old Mar 31, 2015 | 12:04 PM
  #439
95naSTA's Avatar
^^ very OEM+. Looks clean.
Old Apr 1, 2015 | 01:04 PM
  #440
Infinitigirl87's Avatar
Originally Posted by VQnBEYOND
Mods:
Chrome front emblem
20% tint
Oem sideskirts
Ionic dynamics roof spoiler
Black rear emblems
M3 style roof spoiler
Is there anywhere I can find these types of factory rims for my 2001 I30 without going to the Infiniti Nissan car lot?
