I30 OBD2 problem
Old Apr 20, 2013 | 07:45 AM
E=mc^2's Avatar
I30 OBD2 problem
Hello, I have a 2k I30 and my MIL light is on. The problem I am having is I cannot get a scanner to connect to the cars computer. The scanner will power up but will not connect. What should I do?
Old Apr 20, 2013 | 08:28 AM
CauzinDrama's Avatar
check for blown fuse
Old Apr 20, 2013 | 10:45 AM
DennisMik's Avatar
Check 2 fuses, #10 & #12
See page 3 of this diagram for fuse locations.
http://boredmder.com/FSMs/Infiniti/I30/2000/foldout.pdf
Old Apr 20, 2013 | 11:03 AM
E=mc^2's Avatar
Thank you so much. I'll check them tonight!
Old Apr 20, 2013 | 11:08 AM
E=mc^2's Avatar
Both fuse 10 and 12 are good. The scanner gets power and turns on but says it cannot connect..
Old Apr 20, 2013 | 11:52 AM
Try connecting the scanner to another car make sure it's working.?.?
Old Apr 20, 2013 | 12:15 PM
E=mc^2's Avatar
I have used 2 different scanners... Stopped by Oreillys the scanner they had did the same thing.
Old Apr 22, 2013 | 09:56 AM
DennisMik's Avatar
How did you check the fuses, did you just look at them? You need to remove them and check them for continuity.
Or you could get a volt meter and see if you have 12 volts on pins 8 and 16 of the connector. Pin 16 has power all the time, pin 8 you need to have the ignition switch in the ON position.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
