2004 I35 p2135 and p1800 code after cross country ship and weird clicking noise
I just moved from Texas to Washington and picked up my car at the shippers. When I got in the car and turned it on for the first time, I got that clicking noise you get when the blinker or emergency lights are on. It turned off after about 30 seconds. Wierd. So I turned the car off and started it again and the same thing. No blinkers were on and the noise went away on its own about 30 seconds later.
I drove about 45 minutes and stopped and got lunch. After lunch, I turned the car on and nothing clicked. Cool! It went away. I was an intersection turning left on a green arrow. I put my foot on the accelerator and I lost all acceleration in the middle. A bunch of lights came on the dash including the check engine light TSRC or something, and a few others. I was able to limp to a parking lot at about 2-3 miles per hour (basically the transmission was pulling the car forward like if you just take you foot off the gas). I have a bluetooth scanner in the car and I got the following two codes: p2135 Throttle/Pedal Position Sensor/Switch "A" / "B" voltage correlation and p1800.
I turned the car off, researched for a bit, then turned it back on. The check engine light was still on, but not the other lights. I drove around the parking lot testing my acceleration and everything seemed fine. I took a gamble and drove home and got here safely.
I have cleared the codes and drove it around today without the acceleration issue. However, the weird clicking is still happening. And a little time after putting the car into reverse or drive, the doors all lock. They arent locking when they are supposed to. When you put the car into park, the doors are not unlocking like they used to.
Does anyone have any clue what happened here? Is my Throttle body sensor bad? Why was I hearing the clicking when I first got the car back?
raffivegas
Aug 23, 2015 09:54 PM
kirkhilles
Aug 8, 2015 10:53 AM
Jcof88
Aug 3, 2015 10:43 PM
