Crankshaft position sensor
Old Mar 28, 2017 | 06:50 PM
htom6276's Avatar
Car has been hard to start lately. Usually cranks for 10 seconds or so before it will start. Sometimes have to do it twice. Check engine light is one and the code is P0335 (Crankshaft Position Sensor A Circuit). I read online somewhere that I might need to replace the sensor. Anybody Know where on the car it is located? '02 I35.
thanks
Old Mar 29, 2017 | 02:55 PM
DennisMik's Avatar
the sensor detects the teeth on the flywheel, so it is mounted in line with the flywheel. It is on the bottom side of the engine, not true bottom bottom but somewhat towards the radiator.
Old Mar 30, 2017 | 08:20 AM
shodog's Avatar
search you tube for a replacement video. I found one when I needed to replace my cam shaft position sensors
