Infiniti i30 motor swap possibilities
Old Apr 1, 2024 | 10:09 AM
NinoBlue's Avatar
Peace y'all, I was looking to swap my VQ30DE motor in my 00 infiniti I30. My first intention is to just swap it with an identical motor but I'm thinking to possibly upgrade to VQ35DE or even possibly a VQ35HR( If its possible). My concerns with upgrading it is whether it will even be worth the trouble and where i would start with going so far as to HR swap it? Btw, im reading about a recall that were on certain VINs and wasn't sure if mine fell under that list, my vin ends in 6008. I really appreciate the help guys, thanks a lot.
Old Apr 1, 2024 | 11:22 AM
RA030726's Avatar
I'm nutty for Nissans
Don't look at any rear wheel drive VQ engines. They won't work.
Swapping in a VQ35 is a massive undertaking. There isn't an easy route. The 2 main options are:
Engine, wiring harness, and ECU have to match, AKA full swap. Lots of extra power from variable cam timing. Option 2, engine timing components need to be swapped to match the old ECU, AKA hybrid or 3.5L on 3.0L timing. This limits power potential due to static cam timing.
Old Apr 1, 2024 | 02:39 PM
NinoBlue's Avatar
Well i guess less options sometimes is better. This will just have to remain an overhaul job moving forward. I don't want to do any thing more than a rebuild/swap. Definitely not in the mood for a harness swap. Its just there isnt much of a market on mods for the vq30de, even when it was new it would seem. Anyways, thanks a lot for the advice, this has helped me narrow down my options greatly.
Old May 29, 2025 | 01:49 PM
C23's Avatar
C23
I have a 2000 Nissan Maxima, engine has died, I found a motor from a 1997 Infinity i30. WIll the engines swap with any issues?
Old May 30, 2025 | 12:21 PM
wezmykat's Avatar
it might work if you never go above 2500 rpm
but the correct answer is no, those are two different engines, VQ30DEK is what you need and a 1997 is a VQ30DE, lost of different pieces between the two
I would look for a 2000-2001 engine and then not have to worry
98maxi
Jul 30, 2018 06:28 PM
Mendize KNight
Nov 24, 2017 03:06 PM
Stuart Ramsey
Apr 15, 2014 04:24 PM
LILMAN
Mar 24, 2008 12:13 PM
Silvia
Feb 11, 2004 04:38 PM
