2000 infiniti I30 door check
Old Nov 4, 2024 | 03:52 AM
Dirtydoug's Avatar
I am having a hell of a time. I guess the part I need is called a door check. Stops door from swinging open. My question is where do I buy them at. I can't seem to find them anywhere.
i have check the local part stores/ dealerships, carparts.com, rockauto.com, and parts geek. All with no luck.
Please help
Old Dec 12, 2024 | 09:08 AM
wezmykat's Avatar
found one on ebay in like less than 5 minutes:
https://www.ebay.com/itm/121056263374
Your other option is to go to the scrap yard and pull one off a used car, maxima i30 will be the exact same part, might be the same on other models too, should be easy enough to find, I would start by removing the broken one so you can compare.
Old Dec 13, 2024 | 08:48 PM
Dirtydoug's Avatar
No luck at junk yards near me. Thanks for the link
Old Dec 14, 2024 | 03:32 AM
Turbobink's Avatar
Is this it?
Old Dec 14, 2024 | 11:55 AM
wezmykat's Avatar
that one is over 50$ but a little research you can find ones that look identical for versas and sentras for as little as 10$
The only way to tell if they fit would be to remove a bunch of them from the junk yard and compare with yours.
infinitijohn
May 12, 2014 07:04 PM
internetautomar
Jul 14, 2006 01:05 PM
BBaker025
May 29, 2002 07:20 PM
adam-99GLE
May 2, 2002 10:40 PM
