View Full Version : 5th Generation Classifieds (2000-2003)
- NY My bad, WTB: Radiator, Thermostat
- NY RADIATOR AND THERMOSTAT
- KY WTB: Metal door sills ("Kick Plate")
- NY BlakMaxStock"00"
- NY WTB: Aftermarket Radio Reciever
- PA WTB: 2000 Maixma Parts
- NH WTB: 02-03 Front Crash Zone Sensor
- NY FS: USAspec digital iPod/iPhone interface - must go
- NY FS: Tein EDFC Motor Kit
- NY WTB: Need all engine mounts and tranny mount!
- PA WTB aftermarket muffler
- NJ FS: 3" ID BBMAF LRMAF for 5th and 5.5 Gen Maximas - $35 SHIPPED
- NY Trading GLE for SE tails...
- NY WTB: Fuel Injectors & Connectors
- SC 06-08 engine cover
- CT WTB-stock tails for LED conversion
- NY 2003 Maxima 6 Speed Fully Loaded
- NJ Lower Intake..
- MA Pick up only - Stock OEM axleback exhaust
- CA WTB:strut mounts
- LA WTB: 6-Speed Shift Knob
- LA WTB: Rear Window Regulators/Motors
- PA WTB PASS SIDE A PILLAR
- FL FS: Grey EuroPerf Wheelskin (PICS)
- NJ WTB: Any Front Lip
- NY WTB 2002 maxima trunk carpet
- TX WTB: AE Rear Lip
- DE WTB Intake Hose, MAF Housing
- TX WTB: 02-03 Parts for Full Swap
- NJ WTB - 2002 ECU 6MT
- PA FS: Sunroof Wind Deflector
- NJ FS: Tein H-tech springs
- MA WTB 02-03 Vias Control Solenoid and Vacuum Tank
- TN WTB: 3.5 Secondary O2 Connector Plugs
- MI wanted: i need 2002 6speed parts
- WA Shift_Max Brembo BBK bracket
- NY Tokico Illuminas & Progress Springs
- NY 5.5 Gen Performance Part Out
- RI FS: 2003 MAXIMA PARTOUT
- RI 2003 Maxima Part out
- UT WTB: 2000 Infiniti i30 ECU
- NY WTB 2000 SE gauge cluster
- FL apexi intake filter with 3" adapter
- FL FS: The oh so RARE, HOTSHOT Headers/Y-pipe Combo 02-03 VQ35 5.5 gen L@@K
- FL Megan OE-RS axle back exhaust
- NH WTB, stock 02 exhaust, will trade headers
- NY WTB - your old control arm set 03 Maxima
- PA dek bop - 12shipped
- CA FS: Stillen Hi-Flow intake
- MD 19" Rays $700
- KY Wtb hood latch
- TX FS: O2 sim
- GA FS: 2000-2003 HID headlights restored
- NY OEM rear valve cover
- RI FS: smart entrance control unit
- RI FS: headliner
- RI FS: black leather center console
- RI FS: dashboard black
- RI FS: clock
- RI FS: drivers fender
- RI FS: brake master cylander
- CAN-Toronto FS: LH Front ABS for auto
- FL fs heated seat switch
- RI FS: top inside pillars
- RI FS: side mirrors
- RI FS: black leather door panels
- RI FS: se stock trim
- FL BNIP 00-03 5/5.5 Gen OEM Strut Isolator mounts, X2.
- CA WTB Air Filter holder 5.5G
- MO TurboXS UTEC Plug and Play
- RI FS: abs pump
- CAN-Vancouver FS: Parts for a 5th Gen !
- OH WTB: Brake Dust Shields (also called backing plates)
- CAN-Toronto WTB: Left Rear ABS Wheel Sensor
- AZ Hood latch lock - new
- PA 4 OEM Nissan side markers
- CA FS: 95-03 Maxima|I30|I35 -NWP Torque Link Engine Brace
- CA FS: OEM VQ35 Coil Pack
- CA Back to Stock Sale
- FL WTB; 3.5 Lower Intake manifold
- TX good bye once again maxima.org :(
- MD 2002 Bolt On maxima for Sale *video*
- WI WTB: 02/03 EVAP Pressure sensor, connector and pigtail
- NJ stellin lip/sub
- PA WTB: Stillen front lip & a key fob (keyless entry)
- PA FS: 02-03 BRAND NEW STILLEN GROUNDING KIT
- PA FS: 02-03 STOCK FUEL INJECTORS
- PA FS: Brand New ET 300 Racing Brake Front Brake Pads 02-03 Maxima
- PA FS: APEXI POWER INTAKE w/ 3" ADAPTER PLATE
- PA FS: 5.5 Gen Upper Intake Manifold w/ nwp BOP and elbow and TB spacers incl. stock TB
- NJ WTB low mileage auto transmission 02-03
- OR Cleaning house. Take it away!
- MD FS: Timing Advance
- PA WTB Strut/Spring combo
- NH F/S BNIB TEIN S.TECH FOR 5TH GEN
- MD FS: Two Trunk Lids w/ Spoilers (will seperate spoilers)
- TX FS: Thule roof rack "fit kit" #2077, for 200-2003 Maxima
- WI WTB: Dead Starters
- TX wtb springs
- NY tires
- NY lights
- VA FS: Brand new 6MT shifter cables
- NJ WTB: 5th gen Headlights, Cheap
- TX ***WTB*** 02+ Maxima Fidanza/JWT Flywheel
- PA 00-01 Blackout Headlights
- NY stillen rear strut tower brace $100
- VT WTB ehxhaust parts
- MN 02-03 Tailights
- CA WTB: OEM sun roof visor
- NJ F.S.02-03 maxima armrest
- NJ F.S.02-03 maxima headlights
- CA WTB: 02 6MT Passenger Side Drive Shaft
- NY FS: NWP torque link, lower ES sub frame bushings, ES torque mount bushings
- PA In need of dek flywheel asap!
- CT 02 SE tail lights $75 OBO
- NJ 20th anniversary edition lip and sub
- NY 00-01 maxima projector head lights with hidz
- VA WTB: 6 speed shifter assembly
- NC **WTB**** 6 speed shifter cables
- FL FS: Used 4AT 02-03 Shift Knob Assy 349105Y710, Trim G.
- GA Maxima Parts - BBK caliper relocators & Misc items
- MA WTB Stock 2002-2003 OEM Y Pipe
- RI FS: ABS Pump
- RI FS: Struts and Springs
- NY WTB: TransGo RE4F04B-HD2 Reprogram Kit
- TX WTB: 02-03 VQ35 Headers
- CA fs:5th gen BC coilover inserts
- MD FS: rev up cams
- CT Vs nwp spacer kit 3.5vq brand new still in wrapping
- CA WTB RADIATOR FAN WIRE PLUGS
- CA WTB: IACV Plug for DE-K
- NY Max Parts For Sale - Coils, Audio, Heated Steering Wheel
- OH WTB OEM y-pipe for 2000 Maxima.
- AZ WTT My Tokico/Tien OR KSPORT Coilovers set for Your STOCK Set - ASAP!
- CA Tokico Illuminas-Full Set BNIB!
- WA FS: OEM Front and Rear Side Markers
- CA WTB: 01 front and rear motor mounts. condition doesnt matter
- NY FS: MAF Sensor, 5th gen, 22680 AD200
- CAN-Toronto GI: BBMAF custom
- WA FS: CHEAP Maf Adapter
- RI FS: trunk
- RI Side skirts
- MA Wtb lowerig springs
- VA WTB:stock muffler
- MD New OBX headers 00-03 equal length
- MA WTB: fuel rail with injectors 2000-2001
- FL FS: Cattman Y-pipe and stock manifold w/cats
- IL Ebay Find - JIC Coilovers
- NY Stock 2002 BOSE Stereo excellent condition
- NY 2002 stock tailights f/s
- TX 3.5 parts for sale
- FL 2002 Left Headlight (driver side)
- CT Tein S tech springs
- CAN-Other RevUp Oil Pump, VQ30 Heads, VQ30 Timing Equipment, Shortblock, etc
- CT Vq35de Motor for Parts
- RI 2003 manual ecu
- FL WTB: Sunroof Deflector
- TX ***WTB*** 02-03 Maxima Fog Lights..
- FL FS: NWP Phenolic intake spacers and VIAS BOP
- IL WTB 2001 5 SPD ECU
- WTB Coolant Resevoir Tank
- MO WTB Motor Mounts OR trade for motor mount bushings
- MA WTB 5th gen oem door speaker non bose
- TN stock se springs 10 plus shipping
- NY WTB: Stock 00-03 STRUTS!!
- NY WTB: 00-03 MAF Housings
- NM 02-03 Stock VB
- NC FS: Plug and play Haltech for 5.5 gen Maxima
- OH 5.5 Warpspeed Y-Pipe Set of motor mounts that are shot
- MD WTB: DEK Injectors
- RI 3.5 maxima injectors
- ME WTB: 00 Passenger Wheel Speed Sensor
- NY WTT: AE 17" w/tires for stock 16" w/tires
- WA 4300K OEM Phillips D2R bulbs
- MN FS Twin Cities, MN or Western WI ONLY - Brand new Progress Rear Sway Bar
- PA Headers/Y/Catback
- FL FS/FT 2000-2001 Gauge bezel with Chrome gauge rings attached
- RI Thule roof racks
- NY FS: 5th gen CARPUTER/CARPC items
- CA GI: False Floor & Amp setup
- CA WTB: Tein h-tec springs
- CO 2000 Maxima Parts
- MS FS: TEIN S-Tech drop springs
- NJ various parts. injectors & rails, Bose Sub, Plastic manifolds front and rear!
- MS FS Reverse Indiglo Gauges 5.5 AT 129k
- NY wtb 2000 maxima remote fob
- CAN-Other 2xMAFS, Cold Air Intake Tube
- WA WTB. Bose 6Cd Changer for 2K2 Max
- OH 2002 Stock Parts for Sale
- CA FS: OEM 2000 GLE Exhaust
- NY F/S: Rear license plate lights + chrome inside door handle
- CA FS: fuel filter strainer and mass air flow sensor
- CA Bose 6 cd in dash radio (intermittent cd problem)
- GA wtb coilovers for my 5.5
- CA FS: 5.5 gen HID Retrofit kit for 5th gen
- FL FS: Open ended GD for Real Aluminum Gauge rings $39 shipped
- FL FS: Gauge Bezel with Tuning shop Rings already attached
- FL 02-03 Gauge cluster
- FL Gauge Cluster Lenses in Great Shape!
- CAN-Toronto Knights SRI + AEM + BPI Flowstack
- CA floor carpet
- FL WTB : VQ35DE E (1) /I (1)Valve
- OH Brand new in box full radaiator support 00-03
- CAN-Toronto FS: Split Second A/F box
- MD WTB:Mid Pipe for Short Ram Intake
- MA Lip Kit (w/ Jdub) *****
- NY FS: Exhaust Manifolds, F/R Precats, G35 Sedan Muffler, 03 Stock Muffler Section, etc.
- CA need headlights
- CA WTB:struts combo
- FL FS: 5th/5.5Gen Gen parts all offers welcome
- MA FS: 00 SE 5 speed
- MD SAFC 2 and 5.5 gen 6spd ecu
- CA I30/I35 Door Sills (Grey)
- RI FS AE rear lip
- CAN-Toronto 2002 Maxima Parts For Sale
- TN WTB-Grey armrest 2k2 max SE
- MD UTEC-COMPLETE $925 Shipped
- UT WTB: DE-K front coil pack
- CT 2005 Vq35de Engine
- NJ Wtb: Everything in the pics
- GA Need Crank Sensor
- CAN-Other FS: HID bulbs and ballasts
- NJ WTB: Passenger Side Rear Door
- NJ f/s transmission control unit
- IL WTB: 2003 nissan maxima rear bumper
- ME FS: 2000 SE Stock Catback
- NJ 2002-2003 after market headlights w/ eyelids
- FL WTB: 5.5 Gen Intake Midpipe
- MN Cattman Header+Y-Pipe
- MA 5.5 Gen parts for sale - HID Headlight Assembly, fog light, dead pedal, etc.
- NY WTB: SOLID OR FILLED ENGINE MOUNTS
- Looking for 5.5 Gen Stock Headers
- NJ 01 i30 engine cover/AE engine cover
- RI 2003 maxima 6 speed transmission
- ME FS: OEM Springs/Struts Already Compressed
- NJ Berk Intake no filter
- NJ Progress RSB Racingline FSTB
- NJ Maxima Spare tire
- NJ 5 and 5.5 gen Thule Aero Kit
- NJ 5th Gen Rear seats grey cloth
- NJ 2000 ECU 5 SPD
- NJ Cattman Headers and Y-pipe
- OH 5th Gen Max Parts FS
- CAN-Other 2000-2001 Fidanza Flywheel
- MA 2001 Anniv Edition parts car
- CA FS: VQ35 Upper Intake Manifold
- NY 01 OEM Anniversary edition rear lip
- CA 00-01 DE-K Engine Cover
- NY WTB: 4AT stock valve body
- FL FS: Fire sale!! LED modified parts for 02/03 BOSE
