1997 keyless entry
1997 keyless entry
Has anyone tried to add a factory keyless entry system to a Maxima (97 GLX) without that option from the factory? I'd like to know how it went and how difficult it would be. I'd like to think you can plug the module into the car's electronic lock system and voila. Maybe not??
I would appreciate anyone's input.
Re: 1997 keyless entry
Re: Re: 1997 keyless entry
Originally posted by 95emeraldgxe
just get an aftermarket alarm that offers the feature - shouldnt cost more than 150 bucks
Thanks for the advice.
do you have a GLE or GXE? also, what options does your car have (i.e., power seats, intermitent wipers, security system...things of that nature that would have come in the C&C package?) if you have the C&C w/o the keyless you could very well just get a remote and program it. one way to check is to get in your car, lock the doors and stick your key in the ignition 6-7 times in 10 seconds, if the hazards flash twice your car is MOST likely equipped with the things you need to just get the remote.
We have the entry level model, GXE I'm pretty sure. It has a power driver seat, intermittent wipers, and there is a flashing light for the security system on the dash but I'm not sure that it actually does anything. We bought it used (from a rental fleet... actually not too bad of an experience) so maybe I never got the remotes?? I'll try what you were saying with the ignition tonight. Thanks!
programming keyless remote
Well, I'm back. I ordered a 1999-2002 remote from ebay because that was all that I could find at the time. That didn't work. But that makes sense. Then I found a used 95-99 remote and ordered it.
Here's what I have done.... I did the key in the ignition 6 times and the flashers blink twice. Then the doors are locked and I turn the key to ACC and hit the remote lock button. Then the flashers blink twice and it looks like everything is working. So there is some sort of reciever unit in the car and at least the lock button on the remote works.
But then I take out the keys, unlock the doors, get out and the remote doesn't do anything. I've also put in a new battery in the remote with no luck.
As before, any help would be greatly appreciated.
Re: programming keyless remote
Goodluck
Dave
Re: Re: programming keyless remote
Finally got everything figured out. I had a bad door jamb switch so I had to replace that first. You were correct, you have to unlock and lock with the manual lock on the drivers door while the key is still in the ACC position. The instructions I had were a little misleading because it made it look like you only had to do this if you were programming a second remote. Thanks for everyone's help!
I was wondering if anyone knows whether or not remotes for a 97 Maxima have to have 4 buttons or can they only have three? A friend at a Nissan Dealership took two out of the drawer and gave them to me. But, I realized later that there is no trunk release button. The panic button is in that position with nothing in the position below the unlock button. I think they may be for an Altima or other Nissan. Regardless, my attempts at programming either of the two he gave me have failed. Any advice would be helpful?
ballerchris510
Sep 23, 2015 08:46 PM
