power door lock problem
Old Jul 14, 2002 | 08:37 PM
foxraul13's Avatar
Hey maxima guys, i have a question for you, My driver door lock has failed to work properly, If i hit the door look button all of the locks go down except for the driver side. I have to push it down by hand. I her the mechanizim working but the lock dosnt go down or lock the door, unless I do it by hand. Have any of you had this problem? If so what was the possible remedy? Thanks for your time..
Old Jul 14, 2002 | 08:56 PM
Sudesh's Avatar
Re: power door lock problem
Open the door panel..connect the control switches..keep locking and unlocking while trying to see what's preventing the lock from going down. Thats the only way you'll ever figure it out.
Old Jul 14, 2002 | 09:02 PM
Mizeree_X's Avatar
Getting back to his roots
Re: Re: power door lock problem
Door lock timer. Its a common failure on the Max. Its located under the driver side dash. You can either replace it or try and re-solder the loose connections if you are so inclined. Do a search, it has been discussed before.
Old Jul 15, 2002 | 05:40 AM
«§»Craig B«§»'s Avatar
Re: Re: Re: power door lock problem
I think this is a different problem
I know for myself and another local guy (pj93max) none of the power locks worked at all when the door lock timer failed. After I resoldered them, all the power locks came back to life.
King_Ten_Ahead
Sep 30, 2015 04:27 PM
rbaker100
Aug 31, 2015 11:09 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
