ACT did not make pedal stiffer?
Well, i got my act in, and it is VERY grabby, i am still breaking it in, so it has not gone under very heavy load yet, but the pedal does not seem any stiffer than OEM. I have read that it can be VERY stiff, whats the deal?
I too just had my transmission rebuilt and had the ACT clutch installed. My pedal isn't really stiffer either. The clutch engages a lot closer to the floor though. There is also alot of chatter. I can't wait till I hit 500 miles.
im guessing some sort of sound?
Originally posted by iwannabmw
Since my car was down for three days when I changed the clutch, I didn't notice it feeling stiffer at all. A few months later, I drove a Max with the stock clutch and noticed mine was definitely stiffer.
Originally posted by Dev
I hear a lot of people talking about "chatter" with their clutches...what does that mean?
Originally posted by JAY25
Its stiff when you first install it after that it gets very soft.
I was having fun having my wisdom tooth pulled
Originally posted by Chunger
I just had mine installed today... after aging the parts in my room to a fine vintage of course, and the pedal is very stiff... I can't wait to drive it... I had my nephew pick it up.
I noticed that my pedal was a little stiffer than stock. . . It is a lot stiffer than the JWT clutch or the stock 5th gen clutches I have felt recently. All I can say is that when I was in traffic for 2 hours last sunday coming home from our meet in the bay area, my left leg was not doing well at all. . . I need more leg strength.
Originally posted by GarthG
Glad to see it is finally installed Chung. . . you should like it a lot.
Don't want to walk funny, right?
mine was stiff as all hell until they fixed pedal but its still stiffer than stock
and my car vibrates heavily just like the rest of u...i thought it was cause maxima has a lot of power compared to my friends corolla which barely vibrated when u about to shut off...rounding the 400 mark, hope things go well when i hit the big 5 - 0 - 0
Hmm. I thought mine actually was less stiff than the stock clutch. The other thing is that the engage point is so far UP.Like I can just tap the clutch peddel to shift. I would say its in inch down, if that. I really dont like that. I want it to be close to the ground. Anything i can do about that???
clutch stiffness
Even after about 9K miles my clutch is still about 2 or 3 times stiffer than what the oem was. The engagement point is very high, which, IMHO, is the way it should be.
Going from the ACT to a 2K2 oem sometimes during the same day is a vast difference.
Is there any adjustments that can be made? Why are some pedals stiffer than other???
What do you mean?
What do you mean?
i went to FUNK flex show and smoked so many guys on my way home...i hit 450 miles too...500 is around the corner....
So is this vibrating/clutch chatter on the ACT similar to a slipping worn out clutch chattering? I was thinking of getting an ACT to replace my OEM one when it wears out. To hear that the ACT clutch chatters even when new is disappointing. Does it go away after break-in?
The Wizard
24
Oct 1, 2015 08:47 PM
ef9
Sep 10, 2015 10:35 PM
I did it with a couple of my friends. About 8 hours of total labor involved
