strut installation behind backseat?
Old Jul 21, 2002 | 07:36 PM
Alix85's Avatar
once again, yes i searched 1st:
is it true that in order to install the rear struts in the car that the backseat has to be taken off the get access to it? i dont know if this is just an assumption or if its a fact. let me know, thanks.
Old Jul 21, 2002 | 07:57 PM
Michael's Avatar
Back in a 3rd Gen.
Re: strut installation behind backseat?
Yes the back seat has to come out. It isnt hard to do though.
Old Jul 21, 2002 | 08:17 PM
Alix85's Avatar
how would it be done. i'm not doing the installation, but generally where would the seat be able to come out
Old Jul 21, 2002 | 09:13 PM
keener's Avatar
Remove the lower seat cushion first. This is done by grabbing the front of the seat, about 1 ft in from the door, and pulling up...give it a GOOD pull for it may be snug. After that, remove the back seat by lowering the arm rest and the two screws located behind the plastic caps. Also, remove the screws from the lower corners...each side by the seat belt bolts. The seat should come out with one good vertical pull.
Old Jul 22, 2002 | 05:43 AM
«§»Craig B«§»'s Avatar
there are instructions for removing all the seats on my site in the how-to section
Old Jul 22, 2002 | 12:51 PM
ThurzNite's Avatar
depending on how good you are, you might need to remove the rear shelf. pull on the 3rd brakelight, detach harness, and slide the shelf out.
If you don't wanna bother with the lower butt cushion, you can do like what I did with Lordrandall and push the corners of the lower seat to access the bolts holding the rear back cushion. We used a buncha force to pull the butt cushion up but wouldn't budge. In Altimas and Sentras, there's 2 bolts holding it...but not so with 3rd gen maximas.
Jae
Old Jul 23, 2002 | 12:59 AM
Alix85's Avatar
thanks. craig never lets anybody down
Old Jul 23, 2002 | 10:44 AM
Lordrandall's Avatar
Jae
I got the bottom seat out when I was doing some wiring stuff Jae, it makes it much easier to get the back part off.
I just used a BA screwdriver.
Old Jul 23, 2002 | 11:40 AM
Maxima_Van_WA's Avatar
I used a screwdriver as well, a nice long Craftsman, so I could take it bakc just in case :-)
Old Jul 23, 2002 | 11:51 AM
Same here, gotta love that lifetime warranty. I could care less if I break the screwdriver, just don't hurt my MAX!!!
Old Jul 24, 2002 | 12:21 AM
ThurzNite's Avatar
went to sears tonight...picked up their new catalog that just came out...wish i had more $...
Jae
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
