Did all GLEs have ABS? Mine is a 96
Old Jul 24, 2002 | 08:27 AM
phenryiv1's Avatar
Mod her. Ate her.
I have fuses and relays, but ABS is definately not working. My brake resivior has 4 lines exiting it. I looked in the manual, and it lists ABS operation, but doesnot say whether or not my model has it. Any thoughts?
Old Jul 24, 2002 | 08:41 AM
blizz20oma's Avatar
I'm so hood
Heh, yea...I kinda wondered the question "Do all GLEs have ABS?" myself on your other flatspotted tires post. Do you have an ABS dash light/notice the yellow ABS light turn on when you power up the accessories? It'd be all the way to the left on the warning light panel.
I thought I remember ABS being kind of spotty/car-specific on all models in 95-96 from reading a post or two in the past, but since you can't search for three-letter terms, I couldn't back it up. I guess if your wheels locked up in the flatspotting incident, you most likely don't have ABS.
Old Jul 24, 2002 | 08:42 AM
njmaxseltd's Avatar
Put your key in your ignition and turn it to ON but don't start the car.
Do you have a light on that says ABS?
If you answer yes then you have ABS
If you answer no then you don't have ABS
Old Jul 24, 2002 | 08:47 AM
dmBK's Avatar
How 'bout them cliffs?
no, not standard. my 96 gle doesnt have it
Old Jul 24, 2002 | 08:49 AM
MaxRRR's Avatar
Just FYI- no Maxima had ABS standard until 2000. (I think they had it grouped with the Cold Weather Pack for some wacked out reason...)
Old Jul 24, 2002 | 08:52 AM
phenryiv1's Avatar
Mod her. Ate her.
Thanks, guys. I did the turn-on thing last night after reading the manual (to see if a light lit up), but i noticed that i had some gaps. I did not know if ALL system status lights would come on. Mine does NOT have the ABS light, so I guess no ABS. Just seemed strange, with the relays and fuses in place and all...
Old Jul 24, 2002 | 08:59 AM
Albertt's Avatar
Man, I still wish there was a way to retrofit ABS onto our cars >>
I most likely would have been able to avoid this accident I had once on the LIE in the rain.
Old Jul 24, 2002 | 11:15 AM
95emeraldgxe's Avatar
Re: Man, I still wish there was a way to retrofit ABS onto our cars >>
me too, but on the ocean state in broad daylight
Old Jul 24, 2002 | 12:02 PM
geo1317's Avatar
correct, they where not standard on any models on the 4th gen., however i think they where a stand alone option that was not tied into any other packages, cause i recall seeing a base SE with ABS when i was looking for my car.
Old Jul 24, 2002 | 08:22 PM
arrow96's Avatar
If you look under the hood, just inboard (toward center of car) and below master cylinder, you can see the ABS controller (if you have ABS). It is a silver device with numerous steel brake lines running in and out. It has a green tag on the top saying it is an ABS control unit......
AaronL
Aug 8, 2020 10:31 AM
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
