How to tell if vlsd or not
How do you tell if vlsd or not?
I was looking at a 5-spd tranny at the junkyard yesterday. When I called, they said it was vlsd fer shur, but when I got there they weren't so sure after all. Imagine that. I smelled a rat and didn't buy it.
Anyway, is there any discernible outward difference between an open diff tranny and lsd tranny?
There was a number stamped on the case: 4920BZV
Does that indicate anything?
Thanks!
Thanks!
Originally posted by clee130
If it was a Maxima tranny from the US, then there's no way it could have VLSD.
Is there a difference then between a limited slip differential and a locking differential? The reason I ask is that if you do a car parts search it gives you the option of locking and non-locking (but not open and vlsd). There are about a dozen or so locking diff trannies in the database, in all parts of the US. Were these all Canadian vehicles, or are they lying?
Originally posted by mzmtg
If you look in the holes for the axles...
If you can see straight through it...no VLSD.
The model that the 4th gen uses is the RS5F50A (non-VLSD) or RS5F50V (VLSD).
Okay, this is good stuff to know. Thanks very much! Finally, is the case stamped with the RS5F50A or V numbers anywhere?
Thanks!
Originally posted by Dev
I just bought a 99 Maxima ES 5spd, and im from canada, so how do i tell if it has VLSD or not?
I was told the ones in canada come with it but is there any way of checking?
Dev
Dev
Dev
Dev
Dev
Dev
Originally posted by Stephen Max
I just talked to a parts dealer in Ontario (he seemed a little surprised to talk to someone in Texas). He said that a vlsd transmission has a solenoid in the case that activates the lsd. You might check for that. Anybody know if this is true?
Doubt it. The VLSD isn't "activated" mechanically. There is no on or off. It just works.
spencerwh1
Jun 30, 2016 05:44 AM
Nealoc187
Aug 17, 2001 08:13 AM
