Well, I think I found out how much power our VQ blocks can handle...
It translates to just hearsay, but it makes sense to me. I found this in a thread about the next GT-R engine over at www.automotiveforums.com
Here's a link to the entire thread for those who want to read it. I'm registered as VQuick over there. Please ignore my stupid, speculative ramblings.
http://www.automotivebanners.com/cgi...67&type=iframe
There's a few people who might want to watch their power levels if this is true.*cough*I30krab*cough*
j/k
Originally posted by Mech
At the moment Nismo is conducting evaluations with six GT-R test mules using chassis underpinnings from the V35 skyline coupe at the Renault test facility in France. The engines under evaluation are a V8, the VQ series V6 and the RB series engine stroked to 2.8 litres. Apparently all of these engines are being tested in normally aspirated and turbocharged forms. Unfortunately it seems that the VQ is only good for 400 kw (538 hp) before the block cracks.
j/k
Originally posted by MardiGrasMax
So ~441hp to the wheels using 18% drive train loss, thats still allot. I think the 450hp Ron is talking about is at the crank, so he should be safe.
But hey, you never know...He might just decide to push it some more.One other thing about the block: I'm betting this was pretty much a stock VQ block with an open-deck design. If Nissan could build a closed-deck VQ, I'm sure the block could handle more power. The Honda boys do the same with their drag engines.
Originally posted by NYCe MaXiMa
I'm pushing 950 to all 4 wheels in my triple turbo charged 98 auto.
but i still run 12s at the track
On a good day, when I drive off a cliff, I accelerate at 9.8 m/s^2
Well, I wouldn't mind swapping in with a VQ25DET (280/6400rpm, 300lbs-ft/3200rpm) either .. after driving one ... *drool*
Very interesting thread
Here's the direct link to the first page (Black VQs didn't work for me)
http://www.automotiveforums.com/vbul...ighlight=block
With all of the aftermarket support going to the new VQ35DE I wonder if/how much we will be able to use for ourselves. Now that we have a VI it would be interesting to see if we could find a VVT that would work with our engine a la 3rd gen VE (or at least new cams from JWT). Mardigras findings on a new throttle body would also be a good addition to VQ30DET internals on a boosted engine
If you were going to go all out it would be cool to be able to lower your compression and be able to use some of the VQ35DE parts (crank, rods) to make a more boost friendly VQ33DE. I'm still learning about internals, but right now it seems like you can either go the VQ30DET route to lower compression or try making a NA VQ33DE engine while (probably) raising compression.
-hype
-hype
I have been investigating this open-deck design on our VQs. It may be possible to weld some bars between the sleeves and the block to hold the sleeves still when running serious power. They will flop around under high power. I'll let you know how well it works.
I have heard (I could be wrong) that JWT makes a special "decked" headgasket to help. Not sure that it will though.
I bought an engine recently to start my engine project. It's going to take a while cos no funds
. I will be building over the next year. When I get it built, I hope to be running 20 psi
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
6spd4dsc
Mar 4, 2016 05:19 PM
