How come i have a speed limiter????!!
Ok, after owning my 00'SE 5spd for almost 3 years i finally got her to terminal velocity, and the speed limiter bogged me down at 130mph!! I'm hella pi$$ed, because i was on a high speed freight train with a 5.0, TL, and a 850 on the hi-way. I have an early production SE which came with 16 inchers as opposed to the later 17s. I think its because of this that im limited to 130. And im at only 5500rpm at 130mph with 1000 more rpm to go before redline. I hit this limiter 7 times during this 4 hour long trip just to prove myself right and its always right on 130. And its not rev-limited. Does any of u have this problem?? Because i keep reading u guys taken it up to 140 and 144, etc.... If i wasnt going to get rid of this car in a month or 2, i would definitely figure out on how to disable this.
If i recall.. the Gen1 5th Gen SE's the ones that came with 16 inch rims had Speed Limiters.. probably due to the 16 inch RIms and sh!tty tires..
maybe the Gen2 5th Gen SE with 17 inch rims don't have limiters.. maybe you can swap the ECU
rev limiter
I suspect they put one in for two reasons. 1) liability in case you really hurt yourself with the car, and the more likely 2) make sure that you don't break any warranty parts by operating them outside of their range.
it's been really inconsistent on who has a limter and who doesn't...
even people with 5 speed GXEs have claimed that they didn't have a limiter...i did push my car all the way up to 140 and plus mph before...
if you want to get rid of your limiter, you can either get a ECU swap with another car that doesn't have a limter, or you can save yourself alot of time and trouble by buying an APEXi RSM.
one time i got cut off at 135mph for like 3 times in a row...but i did have 2 blown 02 sensors and as soon as i got that fixed, i pushed my car all the way up to 150 and plus..
Re: Re: How come i have a speed limiter????!!
Originally posted by asu174
So you don't kill yourself and other people.
I was to told only the GLE's were limited of cousre that was to 120mph so consider your self jucky you can tap 130mph.
But since your getting rid of the car; what do you plan to replace it with John.
Re: Re: Re: How come i have a speed limiter????!!
Originally posted by Maxima06071
I dunno, 130mph is already fast enough to kill people and break stuff.
Buy the Apexi RSM as already suggested. I've been over 140 and so far no limiter. If I hit a limiter and it has considerable more RPMs left, I'll be getting a RSM myself. I just like to know I can pull to whatever speed the car is drag limited by if I ever "needed" to. However, I don't think I'll be testing that soon, since I don't feel confident in the POTENZAS because they're NOT ZR rated newer tires.
Re: rev limiter
Re: Re: Re: Re: How come i have a speed limiter????!!
Originally posted by irvine78
that really depends on where u are driving!
Re: Re: Re: Re: Re: How come i have a speed limiter????!!
Very true. On an interstate you can get up to a buck ten without noticing; even then your barely catching up with the soccer moms and wreckless teens.
Originally posted by BLaZin 2k MaX
125??? Are you kidding me I would get rid of the car if it stoped at 125. Iv easly hit 140+. Iv also be contimplating putting wings on the side of my car so I can go flying around LA. hahaha
because you can..
because you can..
im not one of those guys that cruises the interstate at 125+mph... there are better things to do.
Re: Re: Re: Re: Re: Re: How come i have a speed limiter????!!
yeah...i'll be driving up to Bakersfield tomorow and i'm looking forward to getting some nice driving time..nice and fast..
I hope to catch some 3 digit numbers popping up on my speedo for a few minutes at a time.
yea i asked Danis(gold AT/4gen w/SC) and he mentioned u with a GXE can go 140+!! Maybe we should take a ride in my car and u can see how messed up having a 130 limiter is.
even people with 5 speed GXEs have claimed that they didn't have a limiter...i did push my car all the way up to 140 and plus mph before.....
Inconclusive???
Seems like everyone has a different result on this. SO, what the hell is going on here. Nissans finally have different characters?? Thats actually glad to see. I am positively 100% sure my limiter kicks in at EXACTLY 130mph at 5500rpm with 1000 rpm to go, because i hit it almost 10 times!! I was screaming in the car when the 5.0 and TL was passing me at 130+ whem my limiter held me back. Only then, do i feel i need to get that APEX thing, but in the past couple years i always drive way past the speed limit but never DOUBLE it like i did now......
Re: Re: Inconclusive???
Originally posted by ][ 35
so what is this apex thing? is this ECU? are they ava for 5th gen?
It allows you to mess with the ecu and force it to let you go past to cars stock limiter, I believe, correct me if I'm off on my information.
Supposedly, the 4th gens have a way to temporarily override the ECU speed limiter, but if you leave it that way for too long you get a CEL. An on/off switch is probably a way around this.
Re: Re: Re: Inconclusive???
Originally posted by IceY2K1
It's just a guizmo that you install between the ECU and sensors, which "tricks" the ECU by modifying the signal to look like your actually not going as fast.
and is it only good for that reason to by pass the speed limiter?
or anyother function?
thanks
Re: Re: Re: Re: Inconclusive???
what is CEL? and how much do those things run about?
thanks
thanks
hmmm
I dont advocate going over 100, but Nissan advertised the crap out of the 142 top speed. They would be in some doo-doo if you have a limiter (non-GXE). There were tons of print ads with the 142 topspeed.
Re: hmmm
Hmmmmmmmmm...........U got a point there. So should i sue them for not letting me go up to 142????!!=)
here is the one that i did the 140 with, but not with these rims tho, it had stock 16" at the time
DMC
Originally posted by Deven2kStickMax
WRONG DUDE. I had a 2000 maxima sunlit sand, hit 140 in 4th gear and was heading to 160 when i get into 5th gear. There was nothing stopping my car to hit 160, but i was affraid of getting caught. i had the stok 16" rims also...so what are you talkin ABOUT????? there is no limiter on the 5 speed SE's....where is that written? show it to me. even the car i have now i can hit 160...i climb up to 140 easy in 4th gear.
Awww it's soooo dreamy....
Yeah just the GLE's were limited right.
Originally posted by darryl12
What the...I've been 140+ in my 00 SE automatic. No Problem! The initial CAR & Driver test went past 140. Heck a New Altima gets real close to the same mark!
DMC
DMC
kafene.
btw, how HEAVY are you?..
Originally posted by kafene
140+?!?! i have a 00SE auto and the fastest i've gone is 130~132 MPH (and it came w/ the stock 17's). what color is your car? and do u have a .org sticker, cuz i don't.
kafene.
kafene.
Someone else on this thread mentioned it. The Nsssan Print materials on the MAX list 142mph!!!
DMC
Not that I'd do anything like that.
