Does the 4th gen starter go bad EVERY 60k miles?
I replaced my starter at about 61k miles and found out at the time that this is 'normal'.
So now I have about 125k on it and I'm wondering if I should expect the starter to go bad again. It is not showing any signs of failing but I want to be ready if/when it does.
Any comments?
Jim
Any comments?
Jim
Originally posted by MONTE 01&97 SE
I think the 95's had a weak starter and were prone to early failure.
I'm already convinced that it is a known problem that the 95/96 starter dies at around 60k miles although I'm sure there are exceptions.
What I'm wondering is if it goes out EVERY 60k miles.
Jim
Jim
Originally posted by ejj
97 GXE with 92k miles and a 99 SE with 78k miles.
Neither have had starter problems.
Must be a 95-96 thing.
Jim
Jim
The reason is that the 95-96 were 8 tooth starters and were prone to breaking ealier...in 97 they made the switch to a 10 tooth version and now thats all they sell for the 95-96 when you go to replace it,
even at Nissan
-Matt
even at Nissan
-Matt
even at Nissan
-Matt
even at Nissan
-Matt
Jim
Originally posted by NotNew!!NewSN!!
how much does a starter cost mine is def startin to go with 75k miles
Jim
Going on 155k miles on my 96 GXE, original starter works perfectly (Murphy's law - having said that, I will not be able to start my car next time I need to.) I have an automatic, perhaps it's only the manuals that have the problem (starter is usually attaced to flywheel on manual tranny or flex-plate on auto, right?)
Originally posted by nadir_s
I heard its not too hard at all to replace starter yourself... save the labor charge!
Re: Does the 4th gen starter go bad EVERY 60k miles?
Any comments?
Jim
Any comments?
Jim
Finkle
Sep 27, 2015 09:53 PM
