think i can take him?
Old Aug 19, 2002 | 12:31 AM
maxxxed out's Avatar
my friend has been talkin crap and calling me out to race him. he has a 95 four door integra with a LS/vtech engine. will he blow me away or is it a even match? i would have raced him already but his car is in the shop. the only reason why he wants to race me so bad is because i've takin out all of the so-called fast hondas around here. i guess he wants to take out the top dog :P 0o yea i have a stock 2000 max se with a A4 greddy muffler. so what do u think???
Old Aug 19, 2002 | 12:37 AM
Max2000's Avatar
if it's a LS.. you will blow him away.....
if it's a GS-R, it's depend if you ahve auto or stick...
should be an even match
Old Aug 19, 2002 | 01:02 AM
he has a ls block with a gsr vtech head...something like that. i tihnk hes pushing about 250 hp...
Old Aug 19, 2002 | 01:11 AM
Eleebob7's Avatar
As much as i am ashamed to say this, I think the GS-R will win. However, it all comes down to the driver and sounds like he's all talk. Lemme know how it goes!
Old Aug 19, 2002 | 01:49 AM
MaximaZero's Avatar
Needs non-Maxima Friends
the LS/VTEC is a combo to be reckoned with. in a car as lightweight as a crx, you probably wouldnt stand a chance. luckily for you he's got the extra weight of the 4 door teg to haul. i think it will be a good race with the integ with the edge on you.
Old Aug 19, 2002 | 01:53 AM
handsofstone's Avatar
the ls and the gs-r share the same blacok. the heads are a little different. a friend of mine has a type r engine in his civic. i smashed him. wait, i was in my lotus then. but the engine only puts 180 to the ground. and the tourqe is so damn low. you can take him. v-tech does'nt even kick in until 5600 rpm's.
Old Aug 19, 2002 | 12:41 PM
GimmeTorq's Avatar
Off topic but, handsofstone, you a boxing fan?? Just curious about your sn...
The original "Hands of Stone"
Old Aug 19, 2002 | 01:11 PM
yes i am a boxing fan, but that is not where i got the name. i got it from ronnie garvin. and the fact i used to get into fights with guys bigger than myself. and come out not bleeding. roberto Duran was a great boxer though.
Old Aug 19, 2002 | 01:42 PM
pjonkheer's Avatar
beat a GSR...
I smoked a GSR last weekend in my 2K3 6-speed and I am a new manual driver...From a stop I beat him by about 5 or 6 car lengths to about 80mph.
Old Aug 19, 2002 | 02:34 PM
asu174's Avatar
Clay Aiken has fancy genitals
Re: beat a GSR...
He must have been the world's worst driver. Did he stall?
Old Aug 19, 2002 | 02:50 PM
ducky's Avatar
Re: Re: beat a GSR...
Maybe he didn't know he was racing.. har har
Old Aug 19, 2002 | 02:58 PM
pjonkheer's Avatar
No he did not stall. Plus, he knew the race was on because his tires squealed big time.
Old Aug 19, 2002 | 05:02 PM
maxman00's Avatar
maybe I am a crackhead, but stock to stock, the only 5th gen max a gsr would have a chance with, would be a pre 2k2 auto. I have spent some time behind the wheel of a gsr, and I don't see it happening. Don't get me wrong, those little sh*&'s are fast, but.....
Old Aug 19, 2002 | 06:32 PM
pjonkheer's Avatar
Re: Re: Re: beat a GSR...
I agree. I have spent some time with a GSR as well, and while they are quick...the best it can do from 0-60 is 7.1 on a good day.
Old Aug 19, 2002 | 08:11 PM
Y2KMaxGXE-R's Avatar
if you are 5 spd and he doesnt have a VTEC controller, you should slightly pull on him.
Old Aug 20, 2002 | 02:30 AM
CO2kmax
the thing about an ls vtec is that the ls block has good low end torque and the gsr head has good high end. That is what i heard. But the bottom line is the driver. Smoke his ***. good luck
Old Aug 20, 2002 | 02:52 AM
SkylineGTR's Avatar
low torque doesnt matter, if u have very short gears, like for instance the TypeR or Civic Si, same transmission, which is geared very tightly, if u have tight gearing all u need is higher redline to offset going through the gear too quickly. And LS/VTEC are known to put out some good numbers, i think a LS/VTEC hybrid puts out more power than a standard GSR motor.
Old Aug 20, 2002 | 08:17 AM
dblrr900's Avatar
Whoooaaaaa!!!! There is no way he is putting down 250hp... if he is you better just go sit on the couch because he will not only beat you, but your kids will still feel the pain next week!
If he says he is getting 250HP at the crank he is still full of it. The Type R which is fully tuned from the factory is only pulling 200HP. It takes a he11 of a lot of motor work to pick up another 50hp. He must have those special "go-fast" lights on his car.
You should take him no prob if he just has the standard motor and head-work. If he has a Vtec head then he needs a Vtec ECU w/ rewiring and the works. Chances of it running right are slim. But if it is right then he may have some head work too. If that is the case then he MIGHT (Might) have 190hp at the crank.
I think he is just talking stupid trash and making up numbers from his superstreet book.
Old Aug 20, 2002 | 08:18 AM
dblrr900's Avatar
ASU - If you think a new Max cant take a simple GSR then you havent ridden in a 6spd VQ3.5 lately. They are not slow by any means.
Old Aug 20, 2002 | 09:03 AM
asu174's Avatar
Read the original post. He has a stock auto 2K. He's dead.
Old Aug 20, 2002 | 09:42 AM
2001SE's Avatar
YEP....ALL 2k/2k1 autos are very very SLOW
around 7.5 0-60
Old Aug 20, 2002 | 09:51 AM
J30A1's Avatar
If he has an LS Vtec Manual tranny then he will take you. Does he have any mods? If he does things are not looking good for you!
Old Aug 20, 2002 | 10:16 AM
dblrr900's Avatar
Re: Re: Re: Re: beat a GSR...
I was talking about your comment on the 2k3 racing the gsr. Not startin anything, just commenting.
On the note of the origional post, yeah I think the guy is going to have a tough time.
Old Aug 20, 2002 | 10:18 AM
Jeff92se's Avatar
I'm needing a caw
RACE AND FIND OUT!
Old Aug 20, 2002 | 02:29 PM
Texasguy's Avatar
Aint' that the truth!
Old Aug 20, 2002 | 03:17 PM
MichaelAE's Avatar
That all depends upon whether it all depends upon what it depends upon if it depends upon how it depends upon who it depends upon and why it depends upon what it does depend upon. So, to answer your question...maybe.
Old Aug 20, 2002 | 11:16 PM
i will
like i said im waitin for his car to get out of the shop. he has the basic intake, exhaust, and decals. he also has skunk 2 ecu or something. i know his engine in a light wieght honda would kill me but the fact that he has a 4 door integra, it might be even. how much do they weigh ne ways? and were both 5 speed.
Old Aug 21, 2002 | 10:26 AM
Re: i will
if both are 5 spd then the race should be very tight, all stakes are on driver
