Question for those who installed Raybestos QS
Old Aug 27, 2002 | 06:04 PM
karguy's Avatar
Just picked up my Raybestos Quiet Stop brake pads. They come with brake shims that have an adhesive on the side of the shim that goes agaist the back of the pad. When you installed your QS pads did you put an anti squeal compound on the side of the shim that faces the brake piston? Guy at Pep Boys said not to but I don't have any faith in his advice. What did you do? Did you lubricate the brake pad retainers and anti squeal springs? I am using Synthetic High Temperature Brake Grease, what did you use? The lifetime warranty from Raybestos is gone, all they do now is warranty them for life against manufacturing defects. You have to send pads to Raybestos for them to determine if the pad were defective. I ordered my rotors and stainless steel brake lines from Brake Concepts yesterday. I was very impressed with Wood's knowledge and honesty. I'll be doing the brake work sometime next week and I'll post results.
Old Aug 27, 2002 | 06:14 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Question for those who installed Raybestos QS
Considering how the shims are, you probably don't have to use it, but I did anyway, and ~ a month later, they're still perfect. One thing I did notice is that they are harder on the rotors, simply because their ceramic i believe. They left grooves across the entire length of the rotor, more like scratches, but nothing that I'm gonna worry about. Overall, they truly are quiet stops
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
