Car hesitates to start
Old Sep 1, 2002 | 10:38 PM
Dev's Avatar
Dev
Car hesitates to start...need help!
this morning the car didn't start normally. i haven't had this problem so far. when i turned the key, it cranked up 4 or 5 times before actually starting up. it usually gets it on the first shot. it got better as the day went by but i think something is wrong, and i would like to solve it before it gets worse. does anyone know what the problem could be? i dont think its the battery because stereo, etc works, and not the alternator either because i drove around for awhile with no problems.
Thanks in advance,
Dev
Old Sep 1, 2002 | 10:55 PM
jkotel's Avatar
woah, I had the same problem start today... it got considerably colder today and it was wet over here, maybe thats part of the problem? Also, as the day went on it got better.... i just had my 02 sensor replaced, i was wondering if they could have messed something up with that...
Old Sep 2, 2002 | 11:21 AM
Dev's Avatar
Dev
well its still summer here but i guess it could be a tad colder in the garage, though that shouldn't be the problem because the car should be able to start in the winter which is much colder. This morning the car didn't start at all. The ABS, Battery, Oil, and Service Engine Soon lights were on at this time.
Does anyone know what the problem might be?
It makes a cranking up sound, then pauses, then makes another one, and pauses, this is really slow, and doesnt' start after all.
Old Sep 2, 2002 | 11:58 AM
gepetto's Avatar
TB cleaning
Old Sep 2, 2002 | 07:07 PM
JustTry's Avatar
Spark plugs......
Old Sep 2, 2002 | 09:35 PM
Dev's Avatar
Dev
just went to the car for another try and the light are going dim, the "ding" open door sound is getting low in volume as well. so im thinking either the battery or alternater needs to be changed.
anyone know how to tell which one?
Old Sep 2, 2002 | 09:47 PM
jkotel's Avatar
geez, that sucks.... hope that doesn't happen with me anytime soon, money is tight!
Old Sep 2, 2002 | 09:58 PM
Dev's Avatar
Dev
no kidding
some ***** hit me and ran a few weeks ago...
$1300 of damages
Old Sep 2, 2002 | 10:00 PM
Green 2kSE's Avatar
Most likely your battery needs replacement.
Old Sep 3, 2002 | 12:13 AM
spiff56747's Avatar
your battery might be dead already, but... this may have been caused by something else.
try putting the key to the ON position for about 10 seconds, without starting the engine. then, crank it, and if it starts, you can be pretty sure you need a new fuel filter.
Old Sep 3, 2002 | 05:28 AM
Chillin's Avatar
jump your battery
next time you can't start... try giving the car a jump. If the car starts up w/ no hesitation then it's your battery. My suggestion would be not to change anything until you give the car a jump or put another battery in and test it.
Old Sep 3, 2002 | 08:04 PM
Dev's Avatar
Dev
Re: jump your battery
Im getting it jumped tomorrow to take to the dealership.
does anyone know how much stock batteries cost from the dealer?
its its expensive i might as well get an optima yellow top...
Old Sep 3, 2002 | 08:22 PM
costcowholesale's Avatar
check email ! (off topic)
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 7, 2015 04:20 PM
