Karguy explains why our cars NEED NGK plugs!
Old Sep 3, 2002 | 01:45 PM
fst96se's Avatar
This was a PM to me from Karguy sometime ago explaining why the NGK plugs are necessary.
Enjoy!
karguy
Autolite Plugs
The distibutorless ignition system was designed to use the NGK Double Platinum (OEM) plug. The polarity is reversed on alternating plugs. What happens is that 3 plugs fire center electrode to ground electrode. The other 3 fire ground electrode to center electrode and that significantly reduces the service life on non double platinum plugs ie. Autolite, Bosch, Denso Iridium. By designing the system that way the engineers were able to increase the time for saturating the coil by over 50%. They did a fine job, I have yet to hear someone say they had ignition system lack of spark problems.
Old Sep 3, 2002 | 01:50 PM
deezo's Avatar
Re: Karguy explains why our cars NEED NGK plugs!
Enjoy!
Good post!!!!
Now I know why I felt a small drop in low end with the Bosch +4's. They hold to much resistance.
Old Sep 3, 2002 | 01:51 PM
Jeff92se's Avatar
I'm needing a caw
Why would he have to PM you that info?
Old Sep 3, 2002 | 01:52 PM
fst96se's Avatar
Some time ago I was going to buy some plugs, and was asking bout various brands. He PM'd me this message, and he also had some new NGK's to sell me....
Old Sep 3, 2002 | 02:30 PM
CFster's Avatar
Hard to swallow. The coil fires through ground? Huh? The polarity of the vehicles electrical system doesn't change at will.
I'd be interested in learning more about this...
Old Sep 3, 2002 | 02:32 PM
fst96se's Avatar
You sound like an electrical engineer! Enlighten us!
Old Sep 3, 2002 | 02:39 PM
Chino's Avatar
Are you telling me that my car would peform better with NGKs instead of my current Denso's?
Old Sep 3, 2002 | 02:41 PM
fst96se's Avatar
That is what EVERYONE who knows anything about plugs is saying. Including the guys running boost and NOS. They all agree on the NGK's, though some are using one step colder plugs.
Old Sep 3, 2002 | 03:34 PM
Chino's Avatar
Could that explain why I run flat 17s with HAI and rear section muffler?
Old Sep 3, 2002 | 04:49 PM
deezo's Avatar
Could be. I'm really trying to get to the track to see what I will run with my FCP Intake and NGK's. I ran my 15.62 with Bosch +4's.
Old Sep 3, 2002 | 05:25 PM
CFster's Avatar
Not quite. But I fix cars for a living, and I just don't understand what the guy is saying. The ground electrode of the spark plug grounds to the engine block through the threads, or body of the spark plug. When a coil fires, the spark goes through the center of the spark plug up to the center electrode and then jumps to the ground electrode. The current then travels through the engine block, through the ground strap then to the negative side of the battery. There's no way to reverse that flow - you would get a short.
I think it's a line of BS the guy filled him with. There are probably other reasons why NGKs perform better in Maximas.
Old Sep 3, 2002 | 05:28 PM
deezo's Avatar
I never thought of that and what your saying makes a lot of sense.
Old Sep 3, 2002 | 07:15 PM
BC_95GLE's Avatar
Flat 17's ohh man if your running something like that it might be a little more than just the plugs check your Knock Sensor, and possibly your fuel Filter. I Run a 15.4 with a HAI and a Crappy knock sensor. It was 62 degrees at the track then also. I did just buy the new NGK's There expensive but they are cheap insurance. Brian
Old Sep 3, 2002 | 07:56 PM
Lonely Driver's Avatar
I thought stock was single platinum. It sounds like he is trying to explain how a coil for 2 spark plugs work like in gm vehicles. But our maxima has one coil for one plug.
Enjoy!
Old Sep 3, 2002 | 08:08 PM
meccanoble's Avatar
Sports Button FTW
my car has been running like sh*t recently and i got a ecu code of cylinder 3 misfire. had my car since 84,000 miles and never changed spark plugs since (113,000)...doubt guy before me did either. Just ordered some from tustin nissan today for 8.80 a piece along with a fuel filter. Hopefully this solves all problems
Old Sep 3, 2002 | 09:48 PM
Kenneth's Avatar
OG :)
he was not exactly neutral is his analysis.
Old Sep 3, 2002 | 09:53 PM
fst96se's Avatar
You know what? Doesn't much change the truth does it? Truth is, nothing out there performs like the NGK's in the maxima. NOTHING. I would wager that none of the most respected members here run anything other than NGK plugs. SO, as far as I am concerned, you can you take your open mouth smiley and shove a stick in it!
Old Sep 3, 2002 | 10:04 PM
MaxVQ's Avatar
This is only true on cars that share a coil to 2 spark plugs, like a Taurus SHO, or any newish 3.8 V6 by GM. It is called something like a "Waste spark ignition"
Look here:
http://au.geocities.com/ozbrick850/e...boschplat.html
http://shotimes.com/SHO3sparkplugs.html
Take Care,
Old Sep 4, 2002 | 06:18 AM
njmaxseltd's Avatar
This is completely wrong. Our coils have 3 wires, Positive 12V, Ground, and the triger sigal. The trigger signal according the the FSM is about +.5 volts. It never changes. The plug fires the same way every time. Whoever wrote the above statement obviously knows very little about basic electronics.
Old Sep 4, 2002 | 07:30 AM
rmb's Avatar
rmb
Enjoy!
LOL, BS.
But the NGK's do seem to work better for whatever reason(but not that one). It would be interesting to do some track timings with the same Max with different plugs.
-RMB
Lakersallday24
Jun 16, 2019 01:35 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Slamrod
Apr 10, 2016 05:24 PM
Turbobink
Aug 15, 2015 07:20 AM
rhonster
Aug 6, 2015 05:46 PM
