2nd (Replacement) Starter Failed After Only 9 months
I had the normal grinding noise that others have experienced on cold starts with my Max. After trying everything else I finally had the starter replaced last Mid-December. The problem was solved. This morning the replacement starter failed as well. The car will not start without a jump now. The dash lights, headlights, and readio all work. So it is not the battery. I am wondering now if the problem is indeed the starter, or another underlying problem (maybe electrical) with the 95gxe. Does anyone have any insight? Or has anyone had the same experience? Please let me know.
Just because your lights work don't think that your battery has to be good; it takes a lot of current to turn over the starter motor.
Clean the battery terminals and battery posts. It doesn't have to be covered with white crud to be corroded. Lead oxide is a very good insulator; clean the battery terminals with a wire brush until they are shiney. Also, check the water level of the battery and top off as necessary with distilled water.
If that doesn't work, take your battery out and have it tested at AutoZone.
Originally posted by Scruit
I jump-star works, then your problem is insufficient voltage/cuurent. If the starter was bad then it wouldn't respond to a jumpstart, IMHO.
Maybe a bumpstart...
vingodine
45
May 21, 2016 12:46 PM
laparka66
Aug 6, 2015 09:36 AM
