Weird tire wear??
My rear tires have weird wear on them, when you run your hand around the tire every other tread block is uneven, the back edge of one block is higher than the front edge of the next block. Also it seems like just the outside edge of the tread has worn more than the rest of the tire. What does this mean the aligment is off?? Thanks.
-Shing
I'm getting strange tire wear also, except it's a bit different. My right front is wearing like it would if it was overinflated (wearing more in the center), but I check the pressure almost every day and it's a bit under spec. Any ideas?
Worn struts in the back.
HerpDerp1919
Sep 29, 2015 02:02 PM
