Auto window mod.
Auto window mod.
Have any of you out there modded your max so that your rear windows have the auto up/down feature from the drivers door controls? I wonder if the switches would fit? It seems if they would it would mearly be a matter of using the same controls that the front doors use. Anybody got a tech manual that shows anything?
someone posted this a while back. i think they found that it was more trouble than it was worth since you need some limit sensor and a different motor?? but that was to use the driver side assembly on the passenger side, before the 2k2.
maybe easier if you get a 2k2 assembly. it's more than the switch i know.
Originally posted by Kojiro_FtT
Correct. A friend of mine hooked up an "Auto All" button in his Intrepid. He recommends not messing with it, it was a nightmare. Though it is cool to hit one button to close all your windows...
I seriously dont see why not use auto window modules from a car alarm, they are easily triggered by a momentary switch. There are a ton of blank plates on the max dash (and center console if you dont have heated seats). You could put in a very OEM switch for ALL down or up.
They basically watch the load like the switch does. As I recall, most of the wires are in the kick panel, except for the driver window.
REDinLV
Aug 15, 2024 12:30 AM
