Rough Idle/ Stalling results
Old Sep 23, 2002 | 05:22 PM
JUDE's Avatar
I had posted that my Maxima was idling very rough and kept stalling out at low rpms. I removed the intake and took the car in to the dealer. I have an extended warranty. Here is what they found wrong with the car:
-Customer states car shutting off, upper intake gasket broken, replaced
-Customer requests CV boot inspection , found r/s outer boot cracked, replaced.
-Customer states check engine light on, found code p0100 MAF Sensor circuit, replaced air flow meter.
-Thumping noise when shifting gears, found both front and rear lower mounts cracked, replaced.
All in all, they charged my extended warranty co $970 for parts and labor.
My first question is, did my intake cause the intake gasket failure? Second, isn't that a lot of things wrong for a car with only 54k miles? Also, the say my belts are cracked, $120 to replace.
Old Sep 23, 2002 | 05:36 PM
JeffesonM's Avatar
living out of a maxima...
man if the warranty company is covering it, tell them to replace everything!!!
Old Sep 24, 2002 | 08:35 AM
JUDE's Avatar
That's what I figured. The only thing I didn't do was the belts because they would be out of pocket for me.
Old Sep 24, 2002 | 06:13 PM
JUDE's Avatar
So....... Does anyone think that the Stillen Intake was the cause for the intake gasket and eventual MAF Sensor failure?
Old Sep 24, 2002 | 06:34 PM
ny96max's Avatar
iven never heard of a 4th gen having a MassAir Flo sensor go bad due to an intake. Sounds like its just a bad part.
How hard to you drive your car BTW??..... cracked motor mounts and cv boots??
Ant
Old Sep 24, 2002 | 06:43 PM
gepetto's Avatar
if you're at 57k thats pretty close to the 60k service. most likely, your belts are cracked/very shiny and need to be replaced.
Old Sep 25, 2002 | 10:16 AM
JUDE's Avatar
Ant
I drive pretty fast. I do occasionally experience wheel hop, which could lead to the cracked motor mounts.
When I first got the car, I was told that the previous person probably drove it like the batmobile because all four rotors were badly warped.
The MAF was fine when I dropped the car off at the dealer, maybe they screwed it up when changing the Intake Gasket. I'm wondering if the Stillen intake cause the intake gasket failure. I'm wondering if its ok to put the intake back on now.
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Sep 27, 2015 08:37 AM
