window switch
Old Sep 27, 2002 | 04:38 PM
slacky92's Avatar
window switch
My 92 gxe passenger window was being hesitant about powering up for a few weeks . Now it is obsinantly stuck in a down position. Before it would power down from driver or passenger door now and hesitate power up. When I depress driver up switch I can hear relay/switch (?) in passenger door activating but not window motor .
does not seem to be a regulator problem as window is held fast . Any clues to toubleshooting the switches or how to power the motor to go up as it is still hurricane season here in Miami. Thanks for your attention
Old Sep 27, 2002 | 05:45 PM
«§»Craig B«§»'s Avatar
take off the door panel, instructions are on my site for replacing the window regulator
then you can see what's going on and if you need to roll the window up, you can do it by putting 12V and ground to the window motor (it has a large 2 wire connector going to it). If you put + on wire A and - on wire B, it will go one way, if you reverse those, the window will move the other way
Old Sep 27, 2002 | 10:10 PM
wyskibumm's Avatar
Re: window switch
I had the same bizniz happen to me when i bought my car (91se). the passenger front was givin me heck, and when i bought the car a year ago, i asked the guy about it, so he ended up taking $200 off the price. i went to the junk yard, got my self a switch for 20 bux, and its been working great ever since, no more of that hesitation business.
--note= if you want to replace the switch, its gotta be the pass. front switch, otherwise your doors wont lock and unlock, and it will be a mess.
[/B][/QUOTE]
Old Sep 28, 2002 | 12:34 PM
slacky92's Avatar
easy window up fix
Pried up the passenger switch plate in front of the switch with my thumb (there is plenty of play in this piece of plastic) disconnedted the wire block from under the switch. It looks like this ::: :: by jumping the two outside connectors in each horizontal row the motor activated and the window went up. Did not have to disassemble door
better diagram of wireing block
X00000 XX
X00000 XX
Now if i can figure out how to take the rest of the plate off I will be able to repace switch without taking door apart.
Old Sep 28, 2002 | 07:35 PM
ssjones's Avatar
re: window switch
See my recent post on power door lock help. Sounds identical to my problem which was resolved by swapping the switch with one from a rear door. If that works, order a new one via Courtesy. When I switched mine, the switch worked in reverse. (up was down, vice versus) I corrected this by reversing the motor leads. HTH
Old Sep 28, 2002 | 08:03 PM
wyskibumm's Avatar
Re: easy window up fix
yeah, i still have my old switch just laying around. i know that it was problematic for me, but if you want it, i can mail it out to ya, maybe it will help you. just let me know
Old Sep 28, 2002 | 09:18 PM
ssjones's Avatar
re: window switch
wyskibumm:
Thanks for the offer. My neighbor works as the local dealership. If he can't rustle up an old switch, he can get one at cost. he got my regulator for $50.
gavin68
Sep 18, 2021 12:36 PM
leatherneck
Sep 30, 2015 09:16 PM
lrb6805
Sep 24, 2015 05:03 PM
