Front Passenger door window malfunction
One fine day, the front passenger door window slipped down into the door all by itself. The electric window lift controls had no effect, except for a clicking noise at the up position.
After disassembling the inner door panel and examining the mechansim, the cable on the the upper track pulley has jumped off, the nylon upper track pulley has a chunk missing on the side ridge where the cable jumped out.
The regulator which rides up and down the fixed track and carries the window is intact, with the epoxy glue joints that hold the window glass to the regulator still holding perfectly.
The lift cable joint to the regulator has come loose.
How do you reconnect the lift cable to the regulator? How do you replace the upper nylon pulley? Will the window glass have to be shattered to get the regulator & track out of the door to order to make the cable clamp repair?
Re: Front Passenger door window malfunction
Originally posted by GDavisCT
...How do you reconnect the lift cable to the regulator? How do you replace the upper nylon pulley? Will the window glass have to be shattered to get the regulator & track out of the door to order to make the cable clamp repair?
--SAM
that is what happens a lot of times when the window regulator breaks, the plastic piece will break and the cable will come loose
you can try to epoxy it back and rewind the cable if you want, but you're probably better off buying a new regulator from the dealer. They are supposedly re-engineered to last longer and not break.
Check my page for replacement instructions in the how-to section
carguy96
20
Feb 6, 2021 06:21 AM
vingodine
45
May 21, 2016 12:46 PM
