Fuel filter from 300ZX
I"m using them....
I read on 240sx.org that they used them. If you goto autozone its part # FF651, its like twice as big as ours. So it should last longer, mine is a PITA to get to so I opted for the bigger Z32 fuel filter.
I am running the 300ZX filter as well
When I did my filter change, I put 1 piece of new fuel line in since the last section was kind of chopped up from me trying to get it off(I got impatient and just sliced it off). Anyway I sprayed a tad of WD-40 on the prongs of the filter so removing it the next time would not be quite as hard.
Matt P.
Matt P.
Originally posted by kratz74
I really can't see the benefit of a 300z fuel filter. The fuel still is pumped atthe same rate to the engine so there is no hp gain or better efficiency. So why do it?
Well on the 3rd gens the standard one is fine, while the 4th -->
gens are a PITA to do and especially the 2nd gen Maximas such as Nismo87se's.
Since the 300z filters have more filter area, it will take x amount longer for this filter to become clogged, etc. than the smaller standard filter.....at least theoretically.
reason
The extra fuel contained in the reservoir can be an extra saftey measure. ie It could be that little bit that could make a difference it the system runs lean for a second under high boost conditions.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
...fuel filter swap is cake on the 3rd gens but im a lazy ****...
