Gen4 vs Gen5 VQ30 Performance: The Final DYNO Showdown
Dyno plot says I have the most area under the Administrator curve
Sorry VQ35 guys...you don't get to play. Go find some V8's to pick on ;-)
So anyways, I went though a lot of the STOCK dyno plots posted or linked at this site and finally compiled some comparison graphs between the Gen4 (95-99) VQ30DE (190HP) and the Gen5 (00-01) VQ30DE-K (222HP), which are below.
Below 3000rpm, the two engines are pretty similar in terms of power output. At 3000rpm and above, the DE-K averages about 10-12 more HP than the DE until about 5500rpm where the DE starts to fall flat on its face, and the DE-K really pulls away with the variable intake manifold cross-over at just past 5000rpm.
So which one is faster?
Well, we need to then consider WEIGHT!
HP to Weight Ratios
As we know, the 5th Gens weigh approximately 200lb more than the 4th Gen's do. So their extra power and torque is at least partially nullified, and this is reflected below after compensating for that.
So it's pretty much a dead heat.
The 5th Gen's still have more pull up top thanks to the VIAS, so one could argue that the 5th Gen's really are faster, but you have to also consider unsprung weight in the form of wheels. The 4th Gen's had 15-16" wheels vs the 5th Gen's 16-17" wheels. Larger wheels are heavier and they are rotating masses which require energy to spin. I forget exactly the rule, but I think it's something along the line of for every 1 pound you add to your wheel + tire combo's overall mass, that equates to something like 8-10 lb of equivalent curb weight.
This is not reflected in the charts, but it would give the 4th Gen's even better performance all around. But not by enough to overcome their massive power deficit compared to the DE-K above 5500rpm.
The 4th Gen's will feel peppier around town and at lower speeds, while the 5th Gen's are the highway beasts that will really knock em dead at higher speeds.
The crossover point seems to be right around the 1/4 mile, because both the 4th Gen's and 5th Gen's seem to put down about the same ET's stock for stock, mod for mod, with the 5th Gen maybe getting a 1-2 mph higher trap at the line. This is where the 4th Gen appears to lose its edge and run out of breathe, meanwhile the 5th Gen keeps on pulling with the VIAS.
In the end, it's pretty much a dead heat and I think this comparison more or less proves that.
Hope you enjoyed reading
great write up... kinda shocked how smooth the 5th gen power/torque curves are compared to ours... liked the power/weight comparison too. maybe when there is more info you could do a 4th gen comparison with the variable intake to a 5th gen(2k-2k1 of course)
Unless somebody with a completely stock 4th Gen hooked one up and dynoed it
Re: Gen4 vs Gen5 VQ30 Performance: The Final DYNO Showdown
Originally posted by SteVTEC
Sorry VQ35 guys...you don't get to play. Go find some V8's to Well, we need to then consider WEIGHT!
Great write up Steve, so it appears if you are a stop light to stop light racer or just a 1/4 mile guy you can be happy without the VI. I have wrestled with the VI purchase and I am going to get it soon, but one thing is certain after 5500rpm are horsepower disappears drastically. I have not driven a 5th GEN but I have driven a VE 5sp and the infamous butt dyno said it had much more pull up top the the VQ, can you possibly overlap a VE stock dyno.
Great post
Re: Re: Gen4 vs Gen5 VQ30 Performance: The Final DYNO Showdown
Thanks all for the compliments
Yeah I was looking at that, too. I was going to include it but wanted to just make this Gen4 vs Gen5 since there were a lot of flame wars in the past about this. hehe. Maybe I'll do another chart later comparing all 3 of those 3.0 engines. Sorry, VG's don't get to play
Here's Lordrandall's 92 SE VE30DE dyno from the dyno forum.
http://forums.maxima.org/showthread....hreadid=128478
Unfortunately, the VE redline is 6000rpm I guess with the limiter shortly after that, so it's tough to compare directly. But at 6200rpm the VE is still making about 155 fwhp whereas the VQ30DE is falling below 140 fwhp. VE top-end with the VTC's and variable runners is definitely better than the VQ30DE with variable nothing.
Originally posted by ivolley
but one thing is certain after 5500rpm are horsepower disappears drastically. I have not driven a 5th GEN but I have drive a VE 5sp and the infamous butt dyno said it had much more pull up top the the VQ, can you possibly overlap a VE stock dyno.
For this comparison I used 5spd vs 5spd dyno's. I always try to use manual dynos because with the automatics, you can't see the low-end properly (because they downshift).
Yes, I think an otherwise stock 4th Gen with the MEVI would lay the smack down on a 00-01 Maxima pretty easily, but then it ain't stock as far as USDM spec goes. Oh well
It's still a very neat and useful mod, though
Originally posted by SprintMax
steve i got some more work for you..
4th Gen MEVI vs DE-K
Find me a G4 MEVI dyno and then a G5 dyno with mods that are as close to the G4/MEVI as possible and I'll take a look at it.
i can't find graphs right now.. but i got numbers
95 5spd with bolton's and MEVI
http://forums.maxima.org/showthread.php?threadid=136409
2001 AE 5spd with bolton's
http://forums.maxima.org/showthread.php?threadid=152627
i can't find graphs right now.. but i got numbers :-D
Anyways, 4th Gen's and 5th Gen's (00-01) are already nearly dead even as far as 1/4 mile times go both stock and modded. Throw the MEVI on a 4th Gen and you easily have a winner
Originally posted by Y2KevSE
You didn't need data to tell DE-Ks are faster. :-D
Re: HP to Weight Ratios
Great post, btw!
Steve one thing I noticed when you posted this...
Something about this thread just made me get out my magazines with 5th generations tested...
Car and Driver June 1999
2000 Maxima SE 5speed manual
0-60 7.0
1/4mile 15.6@91mph
MotorTrend July 1999
0-60 6.7
1/4mile 15.1@94.4mph
Road and Track May 2000
2000 Maxima SE 4speed automatic
0-60 7.8
1/4mile 15.8@88mph
Observation with all these test: With the picture of the engine bay, it clearly shows all these Maxima's are Cali-spec Maxima's which put down less power(About 10fwhp less). There are 4 plugs located on top of the exhaust manifolds in front of the engine Vs. 2 plugs on non-Cali-spec Maxima's
0-60 7.0
1/4mile 15.6@91mph
0-60 6.7
0-60 7.8
1/4mile 15.8@88mph
Originally posted by nismo2020
for some reason mismosh was running one step colder
edit: with stock heat range plugs now
Originally posted by Mishmosh
Damn Courtesy Nissan sold them to me as being stock plugs when I didn't know any better. Will re-dyno when I put in JWT ECU maybe... Will probably dyno stock then JWT ecu--will make for a nice comparo.
let us know how she does then.
It's like....6600 or so...
And I cant get Randy's dyno to load
I just noticed that the 2K VQ HP curve is shaped exactly like my 4th gen's with my VIM. The only difference is I'm making +10fwhp over the 2K at all RPMs below 6200rpms. After that, the 2K makes a couple more HP than me from 6200-6400rpms. I'm even at 6500rpms. Of course I'm not stock though. I've got a VIM, intake, y-pipe, UDP, and B-pipe, but like I've said before, power to weight is a *****. My power to weight ratio (using FWHP) is ~15.6:1 compared to the 2ks ratio of ~17.4:1.
Originally posted by pezking4
And I would kind of like to see some nice friendly VE vs VQ charts
Dave
Originally posted by Dave B
I would like to see a VQ vs VE dyno too and maybe that will dispel the myth that the VE pulls straight to redline.
Dave
Dave
There's no myth. Why is it hard to believe an engine can pull hard all the way to redline? The VQ does it after you put the VI on it.
I know, I drive one...
I was just saying the VQ would pull to redline just like the VE if it also had a VI
I know, I drive one...I was just saying the VQ would pull to redline just like the VE if it also had a VI
Here's some proof and all the VE dynos seem to show the same thing:
http://www.ee.utulsa.edu/~mblehm/pic...eline_dyno.jpg
Dave
That is true, however the VE does hold the power after 5500rpm better than a non VI VQ does. The VQ still owns the VE though, however dynos show that the VI causes a 6-10wtq loss from 3300-4800rpm. That in effect gives it the same torque curve as the VE. It is only after 6000rpm that a VI VQ makes more than a VE would.
I've never seen a VE dyno showing the motor making power straight to the 6500rpm redline. All the dynos I've seen show power peaking around 5600-5800rpms and then falling. Not exactly what I can "pulling to redline". The US-spec VQ will run to redline all day long, it's just that it's making no real power after 5600rpms.
Dave
Dave
Originally posted by carnal_c30
didnt Nabils '95SE 5spd dyno 193hp with Y-Pipe, hybrid intake, and exhaust?
I'm sure some of the SoCal guys will verify this
now he's running a VI and damn it is FAST!
I'm sure some of the SoCal guys will verify thisnow he's running a VI and damn it is FAST!
This gives us nothing to work with except buttdynos and skewed data. They should just say "I ran a 15.2@91mph at 2500 feet above sea level" and not "I ran a 14.5@95mph....corrected". If they are allowed to post their ET/MPHs in corrected form, then all of us should be doing the same thing. Dave
14.41@99.5mph....corrected (pre-VI)
Of course of the VIM the pull after 5000rpms is very impressive. The car feels much smoother in the upper RPMs.The torque curve of the VIM-VQ and the VE are similiar, but the VQ will be making on average about +10-15fwtq from 2000-5500rpms over the VE. After 5500rpms, the VIM-VQ has a huge advantage.
Dave
Unfortunately for us, the Cali guys rarely test their cars in the 1/4 mile and when they do, they correct their ET/MPHs
Dave
Sprinty
11.9@115.3 mph corrected (10 PSI)
