JWT intake install question
Old Dec 23, 2000 | 07:54 AM
plrod Black 95 SE's Avatar
I installed this mod yesterday. Once the air sensor is disconnected from the oem filter housing box, where does it go on the JWT. Or should I just attach it with some ties to a nearby place. This is what I've done and the car is running fine so far/no problems. Just want to be sure I don't screw something up here.
Old Dec 23, 2000 | 09:17 AM
96sleeper's Avatar
the air temp sensor?
If you are talking about the air temp sensor, then it needs to be mounted in the end of the intake. It would work fine if you just zip-tied it near the filter, but it was not designed to pick up ambient temp. It needs to measure flowing air.I drilled a hole in the end of the intake and mounted it with some gasket sealer.
Old Dec 23, 2000 | 11:22 AM
Kenneth's Avatar
OG :)
put mines in the cone filter...
Old Dec 23, 2000 | 03:41 PM
bigtexan7's Avatar
zip tied mine a few inches from the filter. this should give a pretty accurate air temp reading.
Old Dec 23, 2000 | 08:20 PM
96sleeper's Avatar
I had mine there
I had mine zip-tied near the filter, but when I had my car at the dealership, the nissan mechanic told me that it would not work as well there and I needed to move it. So I just put it in the end of the intake.
Old Dec 23, 2000 | 09:46 PM
voltman's Avatar
Does a standard cone intake void the factory warranty? What about a CAI?
Old Dec 23, 2000 | 10:15 PM
tunedup's Avatar
someone told me the JWt intake comes with...
the place to mount the sensor ...
Old Dec 24, 2000 | 03:40 AM
Kenneth's Avatar
OG :)
Re: someone told me the JWt intake comes with...
stillen does
Old Dec 24, 2000 | 06:57 AM
If the JWT comes with a place to mount the sensor, I didn't get the right one b/c there is no place on mine. Interesting though b/c I thought they were exactly the same and the JWT costs less. I would consider this an important detail, although the fix seems easy enough. Thanks for all the feedback.
Old Dec 24, 2000 | 08:57 AM
tunedup's Avatar
what do u mean just zip tie it somehwere
u guys are speaking sooo vaguely its an important part and u can't jus zip tie it anywhere
plz be more descriptive...
everyone is sayin the same thing " just zip tie it"
WHere?
doesnt make sense
Old Dec 24, 2000 | 09:07 AM
Right now mine is zip tied to an open bracket on the strut tower. I know this is not right so gotta go change it right now. Maybe zip tie it to the outside of the filter itself.
Old Dec 24, 2000 | 11:31 AM
bigtexan7's Avatar
I zip tied it to another electrical part which is on the front side of the strut tower right by the filter. The car runs just fine, but I would feel better if the sensor was more protected. The sensor has a tiny electrode under the plastic hoop that looks like it could be damaged easily. This bugs me. I am going to look into mounting it into the end of the filter, but only if I can in a clean, professional way that is easily removable for servicing the filter.
Old Dec 24, 2000 | 11:57 AM
I agree, it's gotta be done correctly or NOT
Well for now it's zip tied just outside the filter housing furthest from the engine and next to the strut tower. But that's gotta change for me - I just got this thing and cannot accept it as is. I bought a part specifically designed for my car and I'm being asked to rig it on...I don't think so --- I don't need this mod that bad.
Old Dec 26, 2000 | 09:50 AM
Hayden
Re: I agree, it's gotta be done correctly or NOT
so is the jwt supposed to come with the sensor mount or not?
Old Dec 26, 2000 | 03:35 PM
got rice?'s Avatar
Re: Re: I agree, it's gotta be done correctly or NOT
From what I found out today, no, JWT does not have an opening for the air intake temp sensor. Drill an opening!
Old Dec 26, 2000 | 04:11 PM
bigtexan7's Avatar
Jim Wolf's does NOT come with a sensor mount. I was also pretty dissapointed.
Old Dec 26, 2000 | 06:50 PM
voltman's Avatar
phuong (got rice?)
so how much can you get the Stillen intakes for?
Old Dec 26, 2000 | 07:54 PM
got rice?'s Avatar
Re: phuong (got rice?)
They're now $159 plus shipping.
Old Jan 10, 2001 | 04:56 AM
Kenneth's Avatar
OG :)
stillen has a (air) temp sensor slot for the 95/96s, fits like oem. off came the jim wolf pop
t6378tp
Aug 24, 2015 07:03 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
3rdmaxse0
Aug 18, 2015 08:25 AM
Maxboy23
Aug 11, 2015 11:59 AM
