**NEED Air Conditioning expert... this is getting out of hand..
I have replaced everything and this is beyond retarted.
I know have replaced the actual unit in the dash and still nothing works.. you can hear the compressor kick in, but no air comes through, hot or cold, so it must be the mode/air door, but I don't know where that is to check for blockage AND nissan said that wasn't the issue.
The only thing not happening is AIR coming out with the AC or HEAT feature. I can use ECON and air comes through when driving, and if i put the unit on manual at 65 degrees all the way up, and crack the sunroof some cool air comes through the vents, but not much at all.
This is retarded.. I need to know if someone can tell me what I can check behind the glove box that I can get to and look at.. I know it has to be something back there.
Any help, point me in a direction, anything.. thanks.
-waldo
-waldo
Do you have
Automatic Climate or hand controls? If Automatic, ask around for a FSM and there is a diagnostic that you might be able to run that will pinpoint the servos and doors. At least this is possible for a 2001.
And
And
Re: Do you have
And
And
Mar 12, 2020 12:06 AM
lux97Max
Sep 4, 2015 05:42 PM
