Rewired corner lights...anything MELT?!
Old Oct 17, 2002 | 09:09 PM
DigitalTexan2u's Avatar
I'm thinking of doing this mod tomorrow, but am wondering if anyone's had a problem with things getting too hot and melting?
Definately don't want to do that!
I plan on just doing the "cut the nub off" mod....
Thanks!
Old Oct 17, 2002 | 09:11 PM
DJSmitty's Avatar
I changed my 97 SE's lights to be true cornering lights with the option to run both filaments together all the time. I blew the 7.5A fuse in the first couple days, and I replaced it with a 10A, and had no problems with both filaments on for a long period of time. Just the brighter one should be fine on the 7.5A.
-Smitty
Old Oct 17, 2002 | 10:19 PM
iregula's Avatar
same deal but i just replaced it with another 7.5. the fuses are 1.99 so i would go the safe route instead of changing it to 10 amps
Old Oct 18, 2002 | 01:11 AM
Nismo's Avatar
havent had anything melt or no fuses burn out yet with my rewired polarg corners
Old Oct 18, 2002 | 06:33 AM
clee130's Avatar
Changing to a higher amp fuse is the unsafe route.
It's like this. Let's say it's a regular 7.5 amp fuse. Suddenly, for some reason, there is a power surge, more than the 7.5 fuse can handle, what happens? The fuse blows and the surge cannot go to the end of the line and ruin whatever is on the other side of the fuse.
Put in a higher fuse and there is a surge. The higher fuse can maybe withstand the surge, but whatever is on the other side of the fuse cannot. What happens? You may be out a $200 product instead of a $0.35 fuse.
Never use a higher amp fuse unless specificed.
Sir Tilus
Mar 22, 2016 01:49 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
Blackwind
Aug 5, 2015 06:35 PM
