ECU question....throttle position switch????
Old Oct 25, 2002 | 04:45 PM
SlowJoeMax's Avatar
i just checked my ECU and i got a code, 1 slow 2 fast.... i looked that up and it means closed throttle position switch... what does that mean??? how can i fix it.. help!!!!!
Old Oct 25, 2002 | 06:01 PM
njmaxseltd's Avatar
0102 = Mass Air Flow Sensor
0203 = Closed Throttle Position Switch
0403 = Throttle Position Sensor.
Which code do you have ???
Old Oct 25, 2002 | 06:04 PM
SlowJoeMax's Avatar
0203 closed throttle position switch
Old Oct 25, 2002 | 06:09 PM
njmaxseltd's Avatar
Are you sure? Your post said one slow and two fast... 0102
Old Oct 25, 2002 | 06:12 PM
SlowJoeMax's Avatar
it actually said both
Old Oct 25, 2002 | 06:14 PM
njmaxseltd's Avatar
From the Haynes manual:
Disconnect the wide open/closed throtle pos. sensor. Connect an ohmmeter to termals 5&6. Check for continuity at the switch with the throttle fully close and again slightly open. There should be continuity with the throttle completely colsed and no continuity with the throttle open.
If the reading are incorrect, replace the TPS.
Old Oct 25, 2002 | 06:21 PM
njmaxseltd's Avatar
If you got 0102 and your MAF fails you car will not go over 2500 RPMs. Reset your ECU and see what happens.
Old Oct 26, 2002 | 09:26 AM
SlowJoeMax's Avatar
ok it looks like i gotta bring it to the shop cuz i dont have a ohmmeter.... and i have a cone filter on my car is that the reasons why its making the 0102 code/?
gavin68
Sep 18, 2021 12:36 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
