question for people who have have window regulators fail...
Old Dec 25, 2000 | 04:59 PM
block's Avatar
Well I pulled my car in the heated garage tonight to let it thow out a little and i rolled the windows down to let some heat in the cabin. I just went out there to roll them back up and move it out but the front passenger side window just clicks when i press up and it goes down fine. have any of you that have replaced regulators had this problem or are the symptoms different?
Old Dec 25, 2000 | 05:07 PM
nubiannupe's Avatar
OG Maxima.org Member
Yep!!
Actually, block, that's EXACTLY how my driver-side rear window sounded before I replaced the regulator. You'll know for sure once U pull off the panel to get to the innards. It only cost me exactly $64.23, shipping included, from Courtesy. Kaleb has the part numbers on his website, and blehm has the instructions on how to take them out on his website. It took me about 30 minutes, more or less, to do the job with basic hand tools. Just don't be a 'Gumby' like me and throw the motor away, thinking that Courtesy was sending me the whole assembly, motor included. I had to go dumptster-diving to get it back!
Old Dec 25, 2000 | 05:12 PM
block's Avatar
two more questions
1. How will I know its a bad regulator when i take the panel off
2. is there anyway I can roll the window up and make it stay so I can drive it? its 14.3 degrees here right now.
block's Avatar
btw thanks for your reply too
Old Dec 25, 2000 | 05:20 PM
nubiannupe's Avatar
Basically, once you remove the panel, and activate the power window, you can feel the motor going, but nothing else happening. That was how I found out. And I saw how there was a plastic piece holding the cable in place, and it was all tore to h***!
As for rolling the window up, probably no safe cure for that except to try and manually pull the window up as far as you can, then maybe taping up the gap. I know it sounds cheezie, but just imagine yourself here where it's somewhere around -14 or so today, then ask yourself do you wanna look like a cheezeball or a popsickle??
P.S. No prob with the answer, bro..... 'each one, teach one'.
Old Dec 25, 2000 | 08:47 PM
«§»Craig B«§»'s Avatar
check out my site for info on how to replace it
I just did a nice writeup a few days ago with written instructions and LOTS of pics
click on my car to go there and then go into "how to"
Old Dec 25, 2000 | 09:06 PM
Sith's Avatar
i bent a flat piece of medal, pulled off the door panel, and stuck it in there so the window is all the way up and the bottom of the piece holds the bottom of the window, and the top of it kind of wraps around the top of the door and holds it there, then just put the panel back on.
NOw i just leave the window lock on so no1 plays with it and don't have to worry about it tell i'm ready.
Old Dec 25, 2000 | 09:44 PM
block's Avatar
ok sith thats a good idea. I'll probably do something like that tomorrow. and thanks craig I'll check your site out.
Old Dec 25, 2000 | 09:50 PM
Sarah99GXE's Avatar
Maxima Princess
that's exactly how my window is staying up right now...actually has been like that for a year now.. I have the regulator in my closed, just to lazy to go get it fixed
Old Dec 26, 2000 | 04:20 AM
Sith's Avatar
lol
ya well i tried wedging cardboard in it, then all kinds of cardboard and tape and i was ashamed to drive around in it with cardboard visible on the window, so i was like screw this i'll figure out a way to stop that SOB.
And it was during winter last year i think it broke too, so it's been about a year for me 2.
I need to buy the part and put it in but damn.
I'm broke and since i already got my eibachs and FSTB sitting in my closet i might aswell finish the suspension stuff first.
Old Dec 26, 2000 | 06:06 AM
DanNY's Avatar
Ad·min·is·tra·tor
well when my reg broke on my old 240 i use a wire coat hanger. shape the hanger like a big S. the loop one on the bottom of the glass. the other end to the metal frame of the inner door. worked for me.
good luck..it's not too hard to swap regulators. just don't lose the 4 10mm nuts top and bottom of the regulator.
Old Dec 26, 2000 | 01:14 PM
Chris Gregg's Avatar
Get Off My Lawn
When mine broke,I cut the cable and pulled the window all the way up, then backed a bolt out and wrapped the cable around it and then retightened it untill I got mine fixed. Just remember when you're pulling out the mechanism and rail to pull the window back up, or (like me) will scratch the tint off your window! STUPID mistake! What was funny is that the new part looked better built than the original peice I replaced! Some replacement parts ARE better!
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
boomerbrian
Sep 4, 2015 08:25 AM
