help, green powder on the battery terminal
Old Nov 2, 2002 | 01:32 PM
colt123's Avatar
Hi:
I discovered that there is green powder around the terminal on my battery terminal. What could cause that?
97 SE
thanks
Old Nov 2, 2002 | 01:35 PM
OdiN1701's Avatar
Re: help, green powder on the battery terminal
This is pretty normal for batteries. As they age you end up with some buildup around the terminals. Just clean with a wire brush or a battery terminal cleaner if you have one. If the buildup gets too bad it can cause a bad connection and your car won't start.
Old Nov 2, 2002 | 01:36 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
battery acid.
Old Nov 2, 2002 | 01:38 PM
Keven97SE
Totally normal. The powder is caused by the acid in the battery oxidizing on the terminals. A routine part of maintenance is cleaning battery terminals. Go to an auto store and buy a terminal cleaner (looks like a cap with stiff metal brushes inside) and a spray can of corrosion cleaner. That will take care of the oxidation. Also, buy some colored felt terminal post rings. That will help prevent future oxidation, although not eliminate it.
Originally posted by colt123
Hi:
97 SE
thanks
Old Nov 2, 2002 | 01:58 PM
turbomax97's Avatar
Re: Re: help, green powder on the battery terminal
or u can go the cheap route.... just be careful that u dont let it touch both terminals. Use coca cola - the kind u drink - and clean each terminal SEPERATELY..... it works just as good, but as the guy said, use a stiff brush, remember it's sulfuric acid in the battery.
Old Nov 2, 2002 | 02:06 PM
OdiN1701's Avatar
Re: Re: Re: help, green powder on the battery terminal
putting some baking soda on and then pouring a bit of vinegar on there cleans good too
Old Nov 3, 2002 | 07:04 PM
2DMax's Avatar
Even cheaper, take a cup of hot water and pout if over the battery.
Old Nov 3, 2002 | 07:16 PM
+COLLANA+
The cheapest
How cheap can we get?
Old Nov 3, 2002 | 08:13 PM
CaLSoNiC
Re: The cheapest
$.50 for a can of Coca-Cola as the man stated above.
Old Nov 3, 2002 | 08:28 PM
ny96max's Avatar
take a can of coke and a scrub brush and go to town then wipe up your mess, done!
Ant
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
bigfrank
Oct 1, 2015 12:51 PM
