How to remove stuck spark plugs?
Old Nov 11, 2002 | 05:49 PM
1FSTMAX's Avatar
I was helping my friend change his spark plugs on his 97 Max. We did five cylinders with no problems, but when we were removing the coil pack from cylinder No. 5, there was a missing piece from the coil pack. A rubber boot that didn't come off when we pulled the coil pack out. When have tried several things to get the boot off, but nothing has worked. We can't get a socket in the hole to remove the spark plug. What can we do to remove the spark plug? Do we have to remove the cylinder head?
Thanks!
Old Nov 11, 2002 | 06:01 PM
Sin's Avatar
Sin
Re: How to remove stuck spark plugs?
Thanks!
Do a search. The solution involves either using long needle nose pliers, or using a stick with some superglue on it.
Old Nov 11, 2002 | 06:04 PM
1FSTMAX's Avatar
Re: Re: How to remove stuck spark plugs?
I tried that. That rubber o ring is really attached to the spark plug. I'll try to take a pic and post it up.
Old Nov 11, 2002 | 06:09 PM
Sin's Avatar
Sin
Re: Re: Re: How to remove stuck spark plugs?
Try a larger socket, and try to twist out the spark plug by grabbing the rubber boot.
Old Nov 11, 2002 | 06:33 PM
D1NOnly34's Avatar
Thanks!
I had this problem literally like 2 days ago. The end rubber socket of the coil pack stayed in the spark plug shaft. What I did was put super glue on the coil pack and jammed it in the hole again. I waited like a day cause I forgot, but it was good cause the glue had dried completely. When I remembered about it, I took out the plug, and there it was connected again. It was a bad coil pack anyways so I changed it for a newer one. If I were you I'd go and check that coil pack to see if ti still works, hope this helps.
Old Nov 11, 2002 | 09:54 PM
1FSTMAX's Avatar
Worked like a charm. Thanks a bunch!
mvm062
Nov 30, 2020 09:00 AM
05RLS2
Nov 7, 2016 05:52 PM
knight_yyz
Nov 6, 2015 02:34 PM
JoshG
51
Sep 21, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
