Is there a reason why fittings are made out of brass?
Is it so that I can destroy them much easier
I was trying to clean my nitrous filter and I fubar two brass fittings. One nitrous gauge reducer and one 1/8" NPT male nipple. I'm going to replace the standard nitrous filter with the high flow 4AN type so it will make maintenance much easier for the next time.
The brass is used because it is significantly softer than the stainless steel. Thus it alone will be damaged if overtorqued, and not the entire hard line. Plus, it also allows for better sealing when torqued properly. If you are having problems, it is probably because you are overtorquing.
I think I'm overtorqing them. I'll take it easy this time around.
Re: Sin has got it >>
welcome to everyone with air suspension's nightmare.. not only is brass soft enough to get crushed by a monkey wrench, but i swear when it heats up it locks the threads on tighter, because i know i can't put some of those fittings on as tight as they are.
I know...those fittings are not cheap
I should be getting my replacement fittings in the mail tomorrow. Let's just hope my recall fuel pressure gauge will be back soon.
Originally posted by Synki
To make us buy more fittings?
I never had a problem with brass fittings. Its the aluminum fittings are nightmares for me.
Mar 12, 2020 12:06 AM
ag90fox
Sep 9, 2015 12:22 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
