Nitrous purge solenoid location?
Old Nov 14, 2002 | 09:11 AM
1MAX2NV's Avatar
I was cleaning out the standard nitrous fiter and adding a high flow nitrous fiter. I have a line running to my nitrous gauge in the engine bay.
1. Should the nitrous purge solenoid be immediately before the nitrous solenoid ?
2. Could I sandwich the nitrous gauge adaptor between the nitrous soleniod and the purge soleniod?
Is there a difference between the two setup?
Old Nov 14, 2002 | 10:25 AM
Jime's Avatar
Re: Nitrous purge solenoid location?
1. Should the nitrous purge solenoid be the immediately before the nitrous solenoid ?
1. If its NOS it goes before the nitrous solenoid, if its NX it goes after the nitrous solenoid.
2. Yes or before the purge.
Old Nov 14, 2002 | 11:21 AM
JAIMECBR900's Avatar
I don't have a gauge under the hood, but I have my purge just before the nitrous solenoid. The closer the better that way you purge everything just before it goes into the nitrous solenoid on the way to the jet(s).
I don't see that either setup will make a diff really, except maybe for room to mount. One may need more than the other depending on where you have yours setup.
Old Nov 14, 2002 | 12:12 PM
1MAX2NV's Avatar
Re: Re: Nitrous purge solenoid location?
I was afraid mounting my gauge line adaptor after the purge solenoid would defeat or degrade perfomance of my purge kit. I could switch the two but it would make mounting the purge soleniod much more difficult because there is less room.
Old Nov 14, 2002 | 12:17 PM
1MAX2NV's Avatar
okay..this might clear it up a bit.
Setup #1. Nitrous bottle -> Gauge adaptor -> Purge solenoid adaptor
-> Nitrous solenoid -> Jets.
Setup #2. Nitrous bottle -> Purge solenoid adaptor-> Gauge adaptor -> Nitrous solenoid -> Jets.
Old Nov 14, 2002 | 01:04 PM
Jime's Avatar
Should work either way, there is little or no obstruction with the gauge adaptor and purge soleoid. There is enough nitrous flow through those fittings for about 300 HP so it shouldn't be a problem.
my03maxima
Jul 28, 2024 07:40 AM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
