Optima battery too short for tie down bars
Anyone with the Optima yellow top battery, it's about one inch shorter than the stock battery. The tie down arms are only partly threaded, so they don't screw down far enough to hold the battery in place. I thought about putting a piece of wood under the battery to raise it up, but that seems like a bad idea to me. What have you done instead?
This might be a 5th gen problem, since I think 4th gens use the red top.
Re: Optima battery too short for tie down bars
Sweet, thanks for the replies. Right now I put a piece of wood under the battery to raise it up. Of course, now the battery sits high and isn't firmly seated in the battery tray, but at least I can tighten the j bars down to hold it firmly in place. I'll check the store for new j hooks.
I didn't want to get an aftermarket tie bar
Originally posted by ericdwong
I've used the block of wood method ever since I put mine in.
Originally posted by thebigsadler
you could just cut an inch or 2 off like i did.. sand and paint the tops.. works fine for me.
I'm getting the aftermarket j-bar where the threads go down further.
edit: Awesome sig pic
Here is a pic of what my Optima Red looked like before I bought the aftermarket J hooks from Autozone.
I decided to get the J hooks after an incident. A few of my friends in my car decided to be a smartalex so I did el swervo left to right a few times at night in a park so they bump their heads against eachother. Well after driving for 2 days after that incident, my car would not start. I checked the battery and the negative cable was loose. The woodblock there served me good til that night, but it was not secured enough to prevent the battery from moving therefore allowing the negative cable to come loose. I went to Autozone to have them charge it for free and picked up the j hooks.
- ßaller
- ßaller
Originally posted by Turbo95Max
if you have a tap and die set. Juss make more threads on the hooks. No need to buy anything and no need to hack anything.
.I'd rather not cut and bend the stock ones, cause I'll have to replace them later if I sell the car.
Aftermarket j-bars seem to be the way to go, and they shouldn't be too expensive.
Thanks all for the suggestions.
I used a die and threaded mine a little further down. The shorter battery height seems to expose the air filter on my pop charger better, so I didn't want to put anything under the battery to raise it.
bigfrank
Oct 1, 2015 12:51 PM
