Hi/Lo H.I.D Kits (High Quality) GD Till Jan 1st!
I need 10 people to do the following prices, thats it!
I'm going to do the buy on any combanation of the following 3 kits.
Heres the specs:
7500K Crystal Blue/White Conversion Kit
There are two types of HID Xenon Bulbs. The D2S type is designed for optimum performance in projection headlight systems. The D2R type features optical shielding and is designed for reflection headlight systems.
Advantage of HID Pro over Halogen
More than 3X the light output (High Intensity)
Enhanced peripheral vision
Improved visibility / illumination
Sunlight color light beam (Higher color temperature)
Lower power consumption
10X Longer life
German made Hella Ballast.
Patented design, 1 HID bulb with Hi/Lo Beam function
Hi/Lo available for H4, 9004 & 9007 only.
HID technology deliver three times the light output while consuming less electricity than halogen light.
Wider beam and Sunlight color enhance visibility.
Blue Color Beam
Kit contains two (2) HID bulbs, two (2) ballasts, two (2) sets of relays and connectors.
Easy to follow "Plug & Play" installation with color-coded connectors.
Same function and specs as factory HID system in Luxury Imports
Warranty: 2000 hours / 2 years.
Only available in H4 bulb
SPECIFICATIONS
Ballast input, nominal - 13.50V
Ballast input, full range - 9.0V to 16.0V
Ballast input, start up @13.5V - 12.50A
Ballast input, start up @9.0V - 15.0A
Ballast input, steady state @13.5V - 3.5A
Ballast input, steady state @9.0V - 5.0A
Ballast output, frequency 450Hz
Ballast output, start up 2.5A @25V
Ballast output, operating 0.45A @85V
Light source 35W, start up 25,000V
Light source 35W, operating 85V
Color Temp. (Kelvin) - 10,000
Lumen (Lm) Max. - 2,300
Life (Hours) Max. - 3,000
Retail $799 GD Price- $530.95 Shipped + tax
Hi/Lo Beam 8000k h4 Conversion Kit
HIGH EFFICIENCY CONTROL UNITS
The 'K2' high efficiency control units deliver you, almost instantly, more than three times the light of conventional Halogen headlamps when you activate the 'K2' HID kit.
AS BRIGHT AS SUNLIGHT FOR THE BEST VISIBILITY AT NIGHT!!
The luminous intensity and color of the 'K2' HID system is truly like harnessing the brightness of the sun. You will be able to see further and wider ahead of you and also have less eye fatigue when driving at night.
THREE TIMES THE BRIGHTNESS AT ALMOST HALF THE POWER!!!
The 'K2' HID system uses 35 watt HID capsules which produce more than twice the lighting output of ordinary 55 watt Halogen bulbs.
MILLENNIUM LIGHT SOURCE, 'HID'
The 'K2' HID headlight system is a completely new technology in lighting that can conveniently fit right into your existing headlight housing.
Features
Ballast: High technology & precision ballast is made by Hella in Germany.
Brightness: Color temperature of the New 8000K is three times brighter than conventional halogen bulbs.
Power: 35W power to save 40% energy consumption.
Focus: Same size as original lamp to reach international standard focus.
Lamp tube: Super hardness lamp tube and UV (ultra violet rays) resistance.
Test Data
Wattage (W): 35
Candela (cd): 202,000
Lumen (Lm): 3,200
Temperature (K): 8000
Irradiation color: Bluish White or Purplish White
Life expectancy: 2,000 hrs
Candela (cd)
The international unit (SI) of luminous intensity. The term has been in use since the early days of lighting when a standard candle of a fixed size and composition was used as a basis for evaluating the intensity of other light sources. This unit is used in measuring headlight output; basically the higher the number is, the brighter the light is.
Lumen (lm)
The international unit (SI) of luminous flux (quality of lights). For example, a dinner candle produces about 12 lumens and a standard 60-watt incandescent bulb produces 830 lumens. The higher the number is, the brighter the light is.
Kelvin (K)
A basic unit of thermodynamic temperature (color temperature) used to measure the whiteness of the light output. The higher the number is, the whiter the light is.
Retail-$899 GD Price - $565.95 Shipped + tax
10,000K Hi/Lo Beam HID Conversion Kit
10X Longer life
Purple Color Beam
Currently available in H4 only.
SPECIFICATIONS
Retail-$899 GD Price-$568.95 Shipped + tax
To sign yourself up or for more info contact me at 860-513-1044 and ask for me, Matt!
or post on here. To start the buy I ask for a 50% refundable deposit via credit card. Again these are the HI/LO beam Kits. Specify your year/model maxima or any other car you may want the lights for.
These are the highest quality aftermarket kits period!
Thanks for the space!
-Matt@XXTuning
Heres the specs:
10X Longer life
Blue Color Beam
SPECIFICATIONS
Features
Test Data
Wattage (W): 35
Lumen (Lm): 3,200
Candela (cd)
Lumen (lm)
Kelvin (K)
10X Longer life
Purple Color Beam
SPECIFICATIONS
-Matt@XXTuning
Originally posted by Ramius83
What is the color equivalence to each of the kits? Thanks guy....
The lower the temp of the kits they will tend to be the white/purplish look, the 6000k kits are very purple, the 7-8000-10000 kits are that bmw/mercedes blue.
-Matt
They do have Dual beam HIDS
I came across this during my search today for dual beam HID kits.
Check it out:
http://www.hidkits.com/products_bixenon.htm
Check it out:
Those kits can be found here: http://www.sportsimportsltd.com/
Jae
Jae
Yes they are the same kits at better prices!
-Matt
Originally posted by funnylittlman
I still don't understand how they did that. We only have 1 access panel, and no bulb cover so to speak.
I'm just being dumb I guess
-Matt
OH ok, via a solenoid/servo?
I hear those don't last too long though...
i think you guys would get better progress if you had a picture of the actual light compared to other kits or just the beam of light period...i know it might be better than mine but i would like to see the crisp of it...
Originally posted by meccanoble
its a 2 year 2,000 hour warranty, much longer than other HIDS sold on the org...
Originally posted by Mishmosh
My question is, who is doing the coverage and what are the terms? A warrantee is only as good as it's backer and often the disclaimers ruin the deal. For instance, how exactly is 2000 hours of use going to be documented? Does the warrantee cover the entire kit or just the ballasts?
-Matt
Originally posted by Matt@XXTuning
There is one bulb that when switched to hi/lo beam changes its angle in the housing, it retracts for low beam and extends for hi beam.
-Matt
-Matt
Not just one bulb
Originally posted by tzmanles
is there anyway I can get just the hi/low beam 9004 bulb without the kit? How does the 2003 Max's with HID stock do hi/lo beams, one bulb?
No, its not just one bulb, it is done by means of using two bulbs in two separate housings. The first housing is the HID capsule for low beams. The other housing is for an incandescent/halogen bulb, high beams.
Re: Not just one bulb
Re: Re: Not just one bulb
so im assuming that you cant take the HID kit from a new max and put it in a 4th generation, huh?
Well you could, but the housing size is different, otherwise all 4th. gens would be running around with them :-).
Re: Re: Re: Not just one bulb
...my only problem is I lost my high beams... is there a HID bulb I can pick up somewhere that does hi/low together?
carid
Sep 9, 2015 05:06 AM
