what gauge speaker wire for 150 watts?
Old Nov 21, 2002 | 12:41 PM
InfamousOrange's Avatar
i am wiring my speakers and i need to figure out what gauge speaker wire to use. each component will be getting 150 watts, so should i use 13ga., or 11ga.? the wire im using is RF Riot Gamma Geometry any help is appreciated.
(P.S.- 11 ga is 1.80/ft and 13 ga. is 1.25/ft so im prayin its 13 ga. )
Old Nov 21, 2002 | 01:01 PM
Whitemax's Avatar
Disco Biscuit
Never hurts to get a thicker cable. (just ask most women ) Its just one of those things, that bigger is better. Might not make that much of a dif, but every little bit helps, especially with higher wattage....
Old Nov 21, 2002 | 02:23 PM
nismo240sx's Avatar
anything less than 12 gauge is not speaker wire...and anything less than 4 gauge isnt power wire
eric
Old Nov 21, 2002 | 02:41 PM
maximadave's Avatar
detailerdaveb@gmail.com
for speaker wire, 16 gauge is more than enough. Use 8 guage on your amp.
Old Nov 21, 2002 | 04:21 PM
AudioAltima's Avatar
agreed! 16 is enough! although I use 12, just cause I had a roll laying around....
Power wire, well... depeds on if you run other amps as well!
Old Nov 21, 2002 | 08:01 PM
TylerBorg's Avatar
if that is your only amp and your not gonna upgrade, 8 guage power 16 speaker
if you have more then one amp 4 to 0 guage power and then 16 speaker or 12 would be fine, the voltage drop on 150wrms on a speaker wire is probably not even audible
BTW no need to pay for RF riot wire
www.knukonceptz.com is like 1/4th the price and wire is wire in 99.9% of the install cases i've seen it dont matter
Old Nov 21, 2002 | 09:10 PM
erty67's Avatar
Decal Specialist
How long are the speaker wires going to be??? The longer, the thicker. If you're only going a couple feet(such as mounting the amp to the box) then 16ga should be fine. If you're going over 5ft., I'd suggest 12-13ga minimum.
Old Nov 22, 2002 | 12:07 AM
nismo240sx's Avatar
im running 10 gauge to horns, and a (probably) a pair *per side* of adire audio koda 6.5's in ported kicks...only getting about 50-90 watts each, but i dont like running tiny wire--it matches better at the amp, so i pay a lil more
ill probably run 10 or 8 for 3000 watts to my brahmas
eric
Miket2006
Mar 1, 2021 03:55 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
