Walbro Fuel pumps
Walbro Fuel pumps
Guys,
I'm a active member with all Nissan forums and was just bringing over a deal on the Walbro Fuel pump kit to you guys.
The kit is
89-94 GSS341 HP pump with 400-858 install kit........$95 shipped overnight....looking for 10 kits purchased total
**There are setups for the 95 up but Walbro USA does not offer this kit. They are done and if you can access the pump and kit # I can do the setup for you.
Take care
The kit is
Take care
FYI - 255lph High Pressure version for 4th GEN... no need for install kit. You could get a 190lph or 255lph (regular) version if that suits your needs...
http://home.earthlink.net/%7Emsue2/Walbro.htm
Originally posted by carnal_c30
hmmm how long is this window of opportunity open?
Go to www.b15sentra.net and www.sr20deforum.com (U12bnextsentra)....buy sell ratings and my web site at www.powertechimports.com and I'm at groupbuycenter
Originally posted by PTIboosted
My name is Jamie. Sorry, yes the pump is the 255HP not standard 255 and I will run this till the 20th of Dec. I am on a B/O till Monday or Tuesday on the pumps.
Originally posted by seximagtr
well count me out, im pushing more than 255 =(
255 is the volume it pumps, HP is High Pressure, suitable for boosted applications
hmmmmm the 255HP is safe for power WAY above any Maxima I know of
oh it's high pressure... i thought it meant horsepower.
Ok.... I will be running the 3.125 pulley on the v1 to start off with and may go a little higher later... is this a good option carnal?
More than enough. Same one I'm running with now.
you can send payment to sales@powertechimports.com and include all info including day phone # and which vehicle the $ is for.
JL
JL
The 255lph pump will support over 500+hp, it's good enough for you!
If it's good enough fo him, that's good enough for me, how should I order this?
Back on page 1 Chunger did a write up on the 4th gen Walbro GSS342 intall if that's what your looking for. My listing show a listing of the GSS341 for the 89-94's. Both 255lph HP pumps, but the feed nozzles are on opposing sides.
89-94 is pump and kit and 95 up is GSS342 pump only
I got my GSS342 walbro fuel pump in the one day. Great guy to deal with, it cost me 80 bucks shipped total.
I never realized our fuel pumps are so small, its like 2 inches wide and 6 inches long =0...
Either way, Jamie is a great guy who takes care of you. Thanks =)
Just keeping you guys up to date that I sold my last GSS342 today and will have my next shipment on Tues.............GREAT stocking stuff for the wife Maxima.
I will hopefully be sending some money your come tuesday.
Originally posted by 96BLUMAX
Does your car run differently if you have this pump and only need the fuel when using no2? Like when the car is not spraying does it cahnge the AFR?
Pump will have very minimal effect on your fuel feed pressure. You may have a plugged fuel filter or contaminted injectors. the pump can only feed what your injectors will allow. If you smell the fuel, you may have a high fuel pres. ( if AFPR is inline) or your injectors setup or eng managment is not calibrated to your setup.
You have to take more than a pump into consideration as this may have solved a simple problem you had previous to the pump install.
**Pumps back instock to be shipped........JL
